Do ppl who own their own trucks recommend getting a microwave
Discussion in 'Questions From New Drivers' started by DAX_, Mar 7, 2020.
  1. DAX_
    DAX_ Medium Load Member
    Sep 4, 2017
    603
    Thanks Received:
    504
    Will this have any major affect of the battery inverter or just overall maintenance
  2. Western flyer
    Western flyer Road Train Member
    Mar 13, 2014
    2,807
    Thanks Received:
    6,796
    No. Just idle the truck while using the microwave.
    Get a 700 watt microwave.
    That way your 1500 watt inverter can run it easily.
    40 bucks at Walmart.
    Owner operator has nothing to do with it.
    I wouldn't live out on the road without one.
    It saves a ton of money.
    And if you have the room in your truck.
    Throw away that crappy igloo cooler that plugs
    Into the cigarette lighter and get one of those
    Small motel refrigerators that plugs directly into
    You inverter.
    80 bucks at Walmart.
    Now your ready to go.
    Coffey, Boondock, beastr123 and 5 others Thank this.
  3. tscottme
    tscottme Road Train Member
    Jul 25, 2008
    14,771
    Thanks Received:
    28,577
    Somewhere out West, in my mind.
    The biggest danger is using long thin power cables from the batteries to the inverter. Doing that is a good way to set your truck on fire. You want the thickest gauge of cable with the shortest length possible to do the job.
    Boondock and Studebaker Hawk Thank this.
  4. danny23tx
    danny23tx Road Train Member
    Feb 16, 2016
    1,494
    Thanks Received:
    2,324
    Austin,Tx
    Yes , I meal prep for up to 5 days worth of home cooked meals . Cheaper and healthier , the foods in trucks stops are are sodium packed and over processed try not to eat that crap .
    Boondock, tscottme and DAX_ Thank this.
  5. lovesthedrive
    lovesthedrive R.I.P.
    Nov 11, 2008
    15,953
    Thanks Received:
    54,484
    Sorrento Maine
  6. tscottme
    Jul 25, 2008
    14,771
    Thanks Received:
    28,577
    Every truck stop also has a microwave or two. I've only been to one truck stop that wanted a dollar to use their microwave. The one's in truck stops aren't always clean, but if you know that in advance and keep your food in some appropriate container to heat it won't matter if the microwave is clean or dirty. I don't have room for one in my truck.
  7. tscottme
    Jul 25, 2008
    14,771
    Thanks Received:
    28,577
    I think the last 2 companies making 12 volt microwaves went out of business. The Amazon page shows small microwaves and 12 volt food warmers. Food warmers are useful, you just have to plan on heating your food 30-60 minutes before you are ready. I used one for 2 years.
  8. danny23tx
    Feb 16, 2016
    1,494
    Thanks Received:
    2,324
    Austin,Tx
    Found a low watt small microwave at Wally world , takes about 1 minute longer to warm stuff up but gets the job done . It's an extremely tight fit in the cubby under my cabinets but totally worth it .
    beastr123 and DAX_ Thank this.
  9. asphaltreptile311
    asphaltreptile311 Road Train Member
    Jun 16, 2016
    1,479
    Thanks Received:
    2,847
    Lots of trucks have built in fridges . Run a big dual door fridge freezer and I have a mini freezer. And not to forget the microwave
  10. mud23609
    mud23609 Medium Load Member
    Mar 9, 2015
    652
    Thanks Received:
    1,444
    No. I recommend getting one of the toaster ovens big enough to cook a frozen pizza instead. Then you can make real food. A half decent one will run you about 100 bucks at Walmart. You can even broil a steak in them.
    I have both and very rarely use the microwave.
    takamine98 Thanks this.
