Eaton 18 speed rattle noise
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Cam Roberts, Jul 14, 2019.
  1. Goodysnap
    Goodysnap Road Train Member
    Jul 12, 2017
    3,718
    Thanks Received:
    9,033
    Without driving it in person, I think what your hearing or feeling may be somewhat normal. Have you driven another with the same age and milleage to compare?
    Lower gears will tend to make a growl/chatter type vibration with some age.
    With no metal on the plugs and it holds all gears fine, I say run er. If it gets worse it's likely reman time anyhow.
  2. Snow Monster
    Snow Monster Medium Load Member
    Feb 9, 2019
    543
    Thanks Received:
    1,297
    A shot in the dark.
    Maybe it's the shifter itself, or shifter related, forks, sliders, just worn out?
    Rideandrepair Thanks this.
  3. AArtemtrk
    AArtemtrk Light Load Member
    May 18, 2019
    56
    Thanks Received:
    59
    Pilot bearing doesn’t spin when clutch is engaged and throw out bearing noise wont change with load or unload it’s either tranny or diff related transferring up drive shaft like pinion hitting carrier.
    Cam Roberts Thanks this.
  4. AArtemtrk
    May 18, 2019
    56
    Thanks Received:
    59
    Check A box countershaft play might just need to re shim it
    speedyk, Cam Roberts and swaan Thank this.
  5. swaan
    swaan Road Train Member
    Jul 12, 2009
    2,942
    Thanks Received:
    4,374
    BC canada
    It's your countershafts in the transmission. They will rattle at low rpm in gear coasting. Completely normal. Just depends on mileage and wear how bad it might be. Sounds like yours is getting tired. My suggestion is keep your rpm above a 1000 when crawling in traffic.
    Nothing to see here
    Wheeljack, Oxbow, wore out and 4 others Thank this.
  6. Cam Roberts
    Cam Roberts Road Train Member
    May 13, 2018
    1,621
    Thanks Received:
    1,938
    Thank you everyone for the feedback. Truck shifts smooth as butter but that doesnt matter. I have a good transmission shop close to here but i believe this trans was rebuilt by this shop already a few years back and then abused by a company driver before i bough the truck. So instead of having them tear into it, its just as cheap to buy a reman unit for 3800 bucks. Thats the price im seeing before the core charge. Yeah i could keep driving it but ill have a few weeks off in a month, so id rather do preventative repair instead of a hefty tow bill and down time.
  7. Rubber duck kw
    Dec 9, 2017
    6,092
    Thanks Received:
    17,686
    It sucks when your transmission does it's impression of a rock crusher 500 miles from home, mine just did a couple weeks ago.
  8. Cam Roberts
    May 13, 2018
    1,621
    Thanks Received:
    1,938
    its an uneasy feeling. luckily i run pretty local. Im 40 miles from home.
    Im wanting to start putting things together and do my research. I believe my trans is a rtlo169118. And its mated behind a cat c12
    I read somewhere that i need some sort of spacers or washers when replacing the flywheel on cat with manual trans. Maybe someone could be more specific on exactly what i need. Also, What is a good severe duty clutch. Im on and off rutted jobsites with heavy loads and stop and go traffic all day.
    Also, Is a 189118 trans basically same trans on outside but heavier duty components inside for more torque? Can you do a simple swap like that or does it require modification. Its a dump truck, so there is a pto on it.
  9. AArtemtrk
    May 18, 2019
    56
    Thanks Received:
    59
    RTLO18918B will swap in no problems just make sure you get as similar a trans as possible eg bellhousing and yoke. The pto shouldn’t be a problem just need dial indicator to setup properly
  10. Freddy2times
    Freddy2times Light Load Member
    Feb 12, 2019
    64
    Thanks Received:
    31
    release bearing is worn out. you said the noise stops when you press the clutch, thats because the linkage forks push on the release bearing to disengage the clutch. if you have no loss in power, or anything else and just a rattling noise which you obviously cant hear over a diesel engine running at 1200 rpm, but can at idle. i think your on the right track assuming the input shaft, but probably not as bad as it sounds.
