Excessive oil passing into air tanks and purging out air dyer, HELP!
Discussion in 'Trucks [ Eighteen Wheelers ]' started by TowHaul, Jul 23, 2017.
  1. TowHaul
    TowHaul Medium Load Member
    Mar 7, 2016
    416
    Thanks Received:
    79
    nah, its brand new, was a pain in the ### to install, i cannot get a refund. and what are the odds a brand new one has identical problems as the old? I did order a new air dryer cartidge which i realize is pointless. I guess no one can help ?
  2. daf105paccar
    Apr 15, 2012
    6,564
    Thanks Received:
    7,293
  3. swaan
    swaan Road Train Member
    Jul 12, 2009
    2,942
    Thanks Received:
    4,374
    BC canada
    New or not it does happen. Rings never seated and it's passing oil.
    Why can you not get warranty??
    We are trying to help but your not listening
  4. nasriza
    nasriza Road Train Member
    Feb 1, 2013
    2,398
    Thanks Received:
    2,074
    Chicago, IL
    this cat compressors are #### ive had them go bad so many times and its always the same thing i've put new ones also with same problems just change air drier frequently and not really much other than that i dont know if you can contact cat directly to see if they have a solution for this but as far as i know they are #### and it just that always pass oil thru
  5. swaan
    Jul 12, 2009
    2,942
    Thanks Received:
    4,374
    BC canada
    It looks like a bendix compressor to me.
    Yes they can be bad from new. I always do a break in with a new compressor.
    I crack a air tank and run the truck on high idle and let the compressor cycle for an hour to seat the rings
    Having said that , I've still returned new compressors for warranty for passing oil.
    SAR Thanks this.
  6. Heavyd
    Heavyd Road Train Member
    Feb 4, 2009
    7,804
    Thanks Received:
    6,253
    Ok, if have oil coming out the blowby of the engine, you have something wrong with engine. Crankcase is being pressurized and oil cannot drain from the compressor housing. I would be doing blow by tests next.
    SAR Thanks this.
  7. TowHaul
    Mar 7, 2016
    416
    Thanks Received:
    79
    oil is NOT leaking out of the blowby tube... again thats why this is a mystery and why i am focusing on the air system
  8. Heavyd
    Feb 4, 2009
    7,804
    Thanks Received:
    6,253
    Ok, your story is not making sense as you keep changing the facts of the symptoms.
    You did say oil is coming out of the blow by still! I reread your post over and over and I keep reading oil is coming out of the blowby. Are you confusing the blowby and purge valve, because they are not the same and totally different things!!!
  9. swaan
    Jul 12, 2009
    2,942
    Thanks Received:
    4,374
    BC canada
    I'm guessing he's confusing the blow by tube with the air drier purge valve
