Excessive oil passing into air tanks and purging out air dyer, HELP!
Discussion in 'Trucks [ Eighteen Wheelers ]' started by TowHaul, Jul 23, 2017.
  1. TowHaul
    TowHaul Medium Load Member
    Mar 7, 2016
    416
    Thanks Received:
    79
    no oil is coming out ofblowby, only purge. Installed another reman air compressor, no oil passing to purge for the first day. Second day same exact symptoms. Im now beyond confused and pissed off
  2. TowHaul
    Mar 7, 2016
    416
    Thanks Received:
    79
    duplicate message
  3. Heavyd
    Heavyd Road Train Member
    Feb 4, 2009
    7,804
    Thanks Received:
    6,253
    Did you inspect the oil drain area where the air compressor bolts to the rear of front cover? The only thing left really is that the air compressor oil isn't draining back into the engine.
    SAR Thanks this.
  4. TowHaul
    Mar 7, 2016
    416
    Thanks Received:
    79
    what should i look for regarding the area where the compressor bolts to the rear of the front cover? what is very confusing is that i have a cat 3126 motor and in that area in front of the air compressor there is a reservoir spout. No idea what goes in there (appears to be oil), what its use is, or purpose. It has no dipstick.
  5. TowHaul
    Mar 7, 2016
    416
    Thanks Received:
    79
    see the funnel in front of the air compressor on this similiar motor to mine? [​IMG]
  6. swaan
    swaan Road Train Member
    Jul 12, 2009
    2,942
    Thanks Received:
    4,374
    BC canada
    That's how you fill the engine with oil when you do a oil change .
    How did you think you get oil in the engine??? Have you not done a service on the engine yet??
  7. TowHaul
    Mar 7, 2016
    416
    Thanks Received:
    79
    i fill it up through the cap on the top. owned the truck for 3 years now, change oil ever 10k miles.
  8. TowHaul
    Mar 7, 2016
    416
    Thanks Received:
    79
    [​IMG] valve cover cap onto top seems like a more logical place to add oil.... I cant even reach that thing on the side with a funnel.
  9. swaan
    Jul 12, 2009
    2,942
    Thanks Received:
    4,374
    BC canada
    Well then I guess you can use either or.
    Depending what the engine has on top of the valve cover the other option is sometimes easier. Depends on application.
  10. TowHaul
    Mar 7, 2016
    416
    Thanks Received:
    79
    any ideas on oil leak?
  11. TowHaul
    Mar 7, 2016
    416
    Thanks Received:
    79
    called bendix they said either the oil return is blocked or air intake is.
