External engine oil cooler 2007 780 w/ 2006 isx
Discussion in 'Volvo Forum' started by Magnum1, Dec 23, 2011.
  1. V8Lenny
    V8Lenny Road Train Member
    1,016
    130
    Aug 3, 2008
    Europe
    200 F is quite optimal oil temperature for the oil viscosity vs. running clearances in the engine. There is a reason why engine manufacturers want it to run at that temperature. Too cold oil also collects water, you want to have 200F or more to vaporize it away.
  3. thehammer69
    thehammer69 Light Load Member
    53
    15
    Oct 31, 2008
    Goose Creek, SC
    I don't even drive my truck until oil has reached 170F. I prefer 200F or higher. The oil additives such as Zinc don't even start working until oil reaches 170F or higher. Until you reach these higher temps, all that is protecting your engine is just the viscosity of the oil and hardly any of the additive package that makes modern oil so great. Also any moisture in oil will evaporate less at lower temps.
    My N14 runs 220 or higher driving down the road...I have over 1.6 million miles on it without ever having an overhaul. Just an Oilguard bypass filter and Chevron Delo 400 oil.
    1. you are fixing a non-issue
    2. you will not get any significant cooling with the small amount of oil that flows through the bypass filter.
    3. you will increase wear if you managed to get your oil temperature running down the road at 150F
    I suggest you go to sites such as Noria.com and bobistheoilguy.com to learn something about oil
    Magnum1 Thanks this.
  4. Magnum1
    Magnum1 Medium Load Member
    567
    28
    Dec 13, 2010
    NJ
    Anyone knows what is the optimal operating oil temp?
  5. V8Lenny
    1,016
    130
    Aug 3, 2008
    Europe
    200-240 F.
  6. Pablo-UA
    Pablo-UA Road Train Member
    7,604
    1,643
    Oct 11, 2010
    Borispol, Ukraine
    why not to use syntetic oil, it is more temperature stabil and may work at higher and lower temperatures well!
  7. Magnum1
    567
    28
    Dec 13, 2010
    NJ
    That's what I do use. I still think above 200 is not good.
  8. Pablo-UA
    7,604
    1,643
    Oct 11, 2010
    Borispol, Ukraine
    Oil cooler is used not to keep oil cooler for better lubrication, but to keep oil cooler becouse oil is used to cool down some engine internals, like pistons to prevent seizing
  9. Magnum1
    567
    28
    Dec 13, 2010
    NJ
    Correct me if I'm wrong: oils do have burn off/ evaporation rate. Hot oil is "stretched" therefore all of the molecules. Besides keeping temp cooler, I might keep the oil in longer
  10. josh.c
    josh.c Road Train Member
    1,105
    420
    Feb 22, 2009
    Knoxville, Tn
    What do you base that on?
  11. Magnum1
    567
    28
    Dec 13, 2010
    NJ
    Smell and the vapors.
    I'll call few oil companies and I'll ask them some questions.
