Fine for not using elds
Discussion in 'ELD Forum | Questions, Answers and Reviews' started by jamespmack, Apr 30, 2017.
  1. jamespmack
    19,980
    Thanks Received:
    215,674
    Does anyone know the fines for not using elds?
  2. javelinjeff
    javelinjeff Medium Load Member
    Aug 30, 2007
    621
    Thanks Received:
    185
    victorville,ca
    Most likely it will be expensive and possible OOS
  3. jamespmack
    19,980
    Thanks Received:
    215,674
    Just a thought that since it is a rule. There should be listed fines. I havent been able to find them
  4. snowwy
    snowwy Road Train Member
    Jul 6, 2009
    20,545
    Thanks Received:
    13,280
    It's not a requirement. So how can there be fines???
  5. Mark Kling
    Mark Kling Technology Contributor
    Sep 23, 2007
    10,935
    Thanks Received:
    4,216
    Statesville, NC
    Implementation Timeline
    The ELD rule is being implemented in several phases:
    The Effective Date February 16, 2016 is the date 60 days after the rule’s publication in the Federal Register.
    The Compliance Date December 18, 2017 is two years from the publication date.
  6. brian991219
    brian991219 Road Train Member
    Aug 10, 2013
    2,954
    Thanks Received:
    5,946
    Lords Valley, PA
    After the compliance date of December 18, 2017 I believe the fines will be from the same table as currently used for paper record of duty status violations. So not having an ELD would be the same as not having a paper log, resulting in an out of service violation, mandatory shut down until into compliance, and fines ranging from a few hundred dollars up to the current cap of $11,000 (which will be adjusted periodically for inflation). That is my off the cuff answer coming from years of working with these rules as a consultant, I will try to get a real answer sometime this week.
  7. jamespmack
    19,980
    Thanks Received:
    215,674
    So if you did have paper you would have records but not complient with elds. But we all will be required to still carry paper logs for back up. Because if there is a issue they require us to document it on paper. So the fine for non compliance cant be as stiff as not installing elds. Because in there own language paper is still complient. See my point.
    flood Thanks this.
  8. UsualSuspect
    UsualSuspect Road Train Member
    Aug 14, 2016
    1,257
    Thanks Received:
    1,979
    Yo Mama's
    I am trying to find the article, like so many you read it and can't find it. I believe if your ELD malfunctions you have 8 days to get it repaired or replaced. The article if my old brain still functions, said if it is still not working after the 8th day the truck is out of service until it is repaired. I will keep looking for it.
    jamespmack Thanks this.
  9. jamespmack
    19,980
    Thanks Received:
    215,674
    Usual, I understand your point. However any way you cut it the paperlogs are still complient. In the right situations. In no way is it a violation of HOS. Because it is still documented. Can not carry the same fines as HOS non documemted. See where im going here
    UsualSuspect Thanks this.
  10. jamespmack
    19,980
    Thanks Received:
    215,674
    First I must say. I try to run mostly short haul. Few days a year Im outside of that. Normally never get close to 14 hours. Im not looking to go full OUTLAW. But the added cost is hard to justify. This will not improve my productivity. And will only add cost.
    Bakerman and W900AOwner Thank this.
