First accident and it is not small..... Will they fire me?
Discussion in 'Questions From New Drivers' started by SayNOtoKILO, Mar 26, 2022.
  1. drh72
    drh72 Light Load Member
    Aug 19, 2012
    175
    Thanks Received:
    301
    Northeast Minnesota
    First...glad your ok, but how don't you know what happened? I would think your company is concerned because you don't know why you hit the guard rail. Not trying to kick you when your down, but I don't want you on the road either if you wreck and don't know why!!
    Cowboyrich and GYPSY65 Thank this.
  2. SayNOtoKILO
    SayNOtoKILO Bobtail Member
    Jul 17, 2021
    9
    Thanks Received:
    7
    That is a good point... And it even concerns me now.... I am overweight but not really excessive fat do have little bit elevated blood pressure and I am on antidepressants. Maybe I should ask for a sleep apnea test
    drh72 Thanks this.
  3. Allow Me.
    May 28, 2009
    10,721
    Thanks Received:
    12,412
    Rancho Mirage, Ca.
    Most guardrails are away from the pavement normally. The exception would be crossing a bridge where it is inches from the fog line. Also most are feet off the ground so the damage would be higher than it shows in the pics. I mean the damage to the area near the step to me is below the bottom of the rail. And quite a bit of damage to the inside area of the tire. Also, truck is on the hook in the pics right ? Good luck to ya' You hit the rail, you drifted off the pavement.
  4. SayNOtoKILO
    Jul 17, 2021
    9
    Thanks Received:
    7
    Ya that was in a construction area, flat land, no shoulder
    Val_Caldera Thanks this.
  5. drh72
    Aug 19, 2012
    175
    Thanks Received:
    301
    Northeast Minnesota
    Maybe bud...Again, glad you're ok. I do hope you get it figured out, once you do I wish you a long trucking career!!
  6. Dale thompson
    Nov 20, 2013
    5,319
    Thanks Received:
    45,328
    commerce twp,mi
    The damage to the inside of the rim looks like impact with something or if it matches the outside damage it’s hard to guess with just 2 pictures. Please stop busting on the newbie EVERYONE has moments of reduced concentration any normal mind wants to wander a bit.
    MACK E-6 Thanks this.
  7. Espressolane
    18,197
    Thanks Received:
    113,042
    Sheared steering arm bolts off at the knuckle. That takes a solid strike with some force.
    Note that it looks like the steering arm is still connected to the cross link.
    Dave_in_AZ and Waterman_99 Thank this.
  8. drh72
    Aug 19, 2012
    175
    Thanks Received:
    301
    Northeast Minnesota
    Looks like the steering knuckle took out the inside sidewall. Nobody is busting on him, just concerned because he doesn't know what happened.
  9. TravR1
    TravR1 Road Train Member
    Nov 9, 2017
    3,695
    Thanks Received:
    9,724
    TX
    Must have dozed off. You see trucks drift off on to the shoulders all the time. It gets on to the rumble belt then jerk back over. We've all done it. It happens.
    In construction zones you can't do that. Gotta be on your best behavior. You won't have any shoulder at all and other trucks will still pass you invariably. You'll feel like a bullet flying down a barrel.
    MACK E-6, austinmike and snowlauncher Thank this.
  10. SayNOtoKILO
    Jul 17, 2021
    9
    Thanks Received:
    7
    And come to think about it I have been even flip flop driving just the day before. Should I be honest with the company about possible sleep apnea or just shut up and keep my story of suspecting tire failure?
