Gear Noise in Mack rears
Discussion in 'Mack Forum' started by akhonaker, Dec 10, 2017.
  1. akhonaker
    akhonaker Bobtail Member
    Dec 10, 2017
    Thanks Received:
    I recently bought a 93 R Mod with Mack Rears, when you are Giving it Fuel everything is fine but, when you let off the Throttle, it makes one of the Loudest "Roaring" noises I've ever heard come from a Truck! Pulled the Inspection cover off the Rear, rear, and turned the drive shaft by hand to check the Back lash and there is very little play in the Pinion but, play from there down,....any Ideas?
  2. Mark Kling
    Mark Kling Technology Contributor
    Sep 23, 2007
    10,935
    Thanks Received:
    4,216
    Statesville, NC
    My jeep did that when the yoke and wheel bearings were going out.
  3. Jazz1
    Jazz1 Road Train Member
    May 7, 2012
    2,373
    Thanks Received:
    4,971
    Thunder Bay On
    If you are lucky it’s a pinion bearing.
  4. rolls canardly
    rolls canardly Road Train Member
    Feb 7, 2009
    1,621
    Thanks Received:
    3,941
    mt. pocono. pa.
    find it now or you will find it in pieces. Hope you're in a warmer place.
    Right now I am getting a vibration in my driveline - and its just too cold to mess with.
    Felt for play everywhere and do not see anything.
    Hope that don't end up in pieces.
