Heat. How how hot does everyone allow? Tire heat sensors?
Discussion in 'Experienced Truckers' Advice' started by Charlie42, Jul 23, 2023.
  1. mustang190
    mustang190 Road Train Member
    Jan 18, 2011
    2,871
    Thanks Received:
    6,180
    Florida Panhandle
    Everything will revert to the ambient temperature.
  2. 4wayflashers
    4wayflashers Road Train Member
    Mar 14, 2014
    1,066
    Thanks Received:
    1,235
    So youre saying heat index and wind chill is not worth mentioning when broadcasting a weather report?
  3. mustang190
    Jan 18, 2011
    2,871
    Thanks Received:
    6,180
    Florida Panhandle
    Yes. Unless you’re naked and outside.
  4. Antinomian
    Antinomian Road Train Member
    Feb 17, 2013
    2,137
    Thanks Received:
    3,390
    Pressure is what I would be monitoring most closely. It will usually say on the tire what the limit is; or you can look it up based on whether it's a load range G or H. All bets are off with recaps though.
  5. Moosetek13
    Moosetek13 Road Train Member
    Nov 1, 2010
    14,818
    Thanks Received:
    18,702
    Burnsville, MN
    Maybe it has something to do with the volume of air inside the tire.
    It is the tire that heats up due to friction, transferring some of the heat to the air inside the tire.
    A lesser volume of air will absorb less heat, leaving more heat in the tire rubber.
    And is air compression linear or exponential?
    Is 100psi twice the amount of air as 50psi, or actually more?
  6. snowwy
    snowwy Road Train Member
    Jul 6, 2009
    20,590
    Thanks Received:
    13,308
    100 psi expands more then 50 psi.
  7. mustang190
    Jan 18, 2011
    2,871
    Thanks Received:
    6,180
    Florida Panhandle
    lual Thanks this.
