HELP, steering shaft will not slide into housing
Discussion in 'Trucks [ Eighteen Wheelers ]' started by TowHaul, Aug 17, 2020.
  1. lester
    Jan 2, 2012
    2,920
    Thanks Received:
    7,890
    NW, Iowa
    Hit it harder?!
    Rideandrepair Thanks this.
  2. Wasted Thyme
    Jan 27, 2020
    7,729
    Thanks Received:
    38,304
    GOAT watching
    That's what she said.
    LameMule and Rideandrepair Thank this.
  3. lester
    Jan 2, 2012
    2,920
    Thanks Received:
    7,890
    NW, Iowa
    I do find it odd that it would be rusted that bad. The outer shaft is on the up hill side so it's not.like water would be pouring in there and rusting. Obviously is can still worknits way up but..
    I dunno man hard to know without being there but if you got it to move one direction you outta be able to get it to move the other. Just keep working it back and forth
  4. Gdog66223
    Gdog66223 Road Train Member
    Dec 30, 2017
    1,871
    Thanks Received:
    2,569
    Coal Town
    Use 2 hands
  5. TowHaul
    TowHaul Medium Load Member
    Mar 7, 2016
    416
    Thanks Received:
    79
    my brother came over, he is the mechanic. We heated up the housing with a map torch, then he put a big vice grip on the end and beat it out. then deburred the end and greased the inside and the rod and basically almost hammered back in. Somehow it moves now (barely?) but it moves and the steering works great. He even saw the pin(?) holding the ujoint had come out and he somehow fixed the ujoint. All seems well but man that thing was STUCK!! so heat, vice grip, a mallet, grease, and pb blast did the trick.
    lester and Rideandrepair Thank this.
