Help with 9 speed transmission
Discussion in 'Questions From New Drivers' started by Evie3, May 15, 2017.
  1. STexan
    STexan Road Train Member
    14,963
    29,160
    Oct 3, 2011
    Longview, TX
    I don't have a problem with 300 but 500 don't sound right.
  3. sealevel
    sealevel Road Train Member
    2,664
    10,282
    May 31, 2012
    U.S. 41
    3 hundred
    AModelCat Thanks this.
  4. AModelCat
    165,108
    Not sure how you can drop 3,000 RPM between shifts when most diesel engines are governed to around 2,100 RPM.
    spyder7723, sealevel and Bean Jr. Thank this.
  5. Yourawahoo
    Yourawahoo Light Load Member
    84
    28
    May 8, 2017
    13 speed to 9 or 10 speed you gotta make up the difference somewhere. RPM drop between gears is the only place you can. You gotta get up to speed with less gears.
  6. sealevel
    2,664
    10,282
    May 31, 2012
    U.S. 41
    He is just over thinking it. Tell him to treat it as a standard H 4 speed. In other words up- down-up down- split-up-down- up- down. No need to ever go all the way over to the left unless using reverse or need a super low gear. Easier than a ten. Tell him it's nothing more than a H. Other than that as others have said forget about speed it's all about rpm and listening to the engine.
  7. Yourawahoo
    84
    28
    May 8, 2017
    OK were just looking at the same numbers differently. There the same. It's just I've been around trucks my entire life, got my cdl on my 18th birthday. There isn't much I don't know about trucks or business of trucking as I have been around both. I've had 3406 cats.8V92T Detroit's, Cummins small cam, big cam. Horton fan cluthes and international oil over air fan cluthes. Air ride, 4 spring Pete and me. Truck. Torsion bar KW. Most people have never heard of these things, so when you questioned me it rubbed me the wrong way. Sorry.
  8. Yourawahoo
    84
    28
    May 8, 2017
    I was a company owner for 25 years. Spent 5K a month on rubber. Tore Cummins down Friday after work, blowing smoke by noon on Sunday.
  9. ChaoSS
    ChaoSS Road Train Member
    3,338
    6,758
    Sep 20, 2014
    At 21 to 18 rpms my truck would have stalled out a long time ago. My truck runs in the general area of 1000 - 2000 rpms, with an rpm drop at shifting of roughly 400-500 rpms.
    spyder7723 Thanks this.
  10. Yourawahoo
    84
    28
    May 8, 2017
    Im sorry but your truck idles at 7. Get a clue driver. 700 that is.
  11. AModelCat
    165,108
    Just a friendly word of advice, name calling doesn't go very far around here.
