How get better mileage in Winter? 2016 Volvo I-shift D13
Discussion in 'Ask An Owner Operator' started by listen2all, Nov 10, 2018.
  1. listen2all
    listen2all Bobtail Member
    Sep 3, 2018
    Thanks Received:
    new O/O here, 2016 Volvo i-shift d13. First Winter as an O/O. Looking for do's & don'ts to get better fuel mileage in Winter season. Thanks
  2. x1Heavy
    x1Heavy Road Train Member
    Mar 5, 2016
    34,017
    Thanks Received:
    42,137
    White County, Arkansas
    You do not worry about minor things like fuel mileage in the dead of winter. You keep that engine going, fuel up at half tanks and proceed towards your delivery as best and smooth as you are able. You are not going to save fuel at 15 mph on ice or fighting headwinds out west at whatever speed you are trying to maintain.
    If you are really intent on saving fuel in winter at any price, then run only I-10 on the gulf coast or maybe I-8 or something like that. That way winter does not affect you much or a bit of rain.
    In my time we are encourage to work March through roughly end of October. Take the winter off and parked it on unemployment because the holiday season is more of a liability than it's worth.
    crocky Thanks this.
  3. Long FLD
    Long FLD Road Train Member
    Mar 4, 2015
    12,056
    Thanks Received:
    49,753
    Your mileage is going to drop no matter what just due to winter blend fuel. If you get decent mileage now then use those same driving habits to get the best that you can during the winter months. You may have to idle a bit more than normal but there shouldn’t be a big difference in idle time if you have an auxiliary heater for your cab.
    blairandgretchen Thanks this.
  4. MartinFromBC
    Oct 19, 2018
    2,769
    Thanks Received:
    12,478
    Unnecessary idling is really about the only thing that you can do to save fuel, besides slowing down some.
  5. blairandgretchen
    Dec 9, 2011
    13,413
    Thanks Received:
    72,257
    South west Missouri
    Yup - pretty much. Just practice the same habits you normally would for better MPG.
  6. crocky
    crocky Road Train Member
    Jun 28, 2017
    1,732
    Thanks Received:
    1,577
    I know this is off topic a bit, but if this is by chance your first winter with DEF on a truck, make sure you keep your def tank filled up. The DEF lines at the bulk fuel pumps freeze up in the hoses. This means you can't pump DEF to fill your tank.
    It's very easy to run into a situation where you can't find any DEF because all the truck stops have frozen lines, so get in the habit of topping it off when its freezing out.
    20 Mule Team Thanks this.
  7. 86scotty
    86scotty Road Train Member
    Aug 27, 2017
    4,524
    Thanks Received:
    12,252
    Appalachia
    Your truck already gets better mileage than anything else on the road! About the only way you're only going to improve it is to quit driving it.
