How much grease monkey stuff you have to know as a new company driver
Discussion in 'Questions From New Drivers' started by Aarrons, Apr 11, 2016.
  1. Aarrons
    Aarrons Light Load Member
    Jul 13, 2015
    242
    Thanks Received:
    75
    Besides loading fuel, I imagine it varies by company.
    An what kinds? Like adjusting the brake pads, changing filters etc
    Thanks
  2. Blackshack46
    Blackshack46 Road Train Member
    Jan 19, 2015
    3,326
    Thanks Received:
    4,250
    Playing in the cow manure, PA
    This is something that is way to wide to answer. Some companies all you can do is fuel, some companies allow light bulb changes. Maybe a company exists that you can do an inframe on the side of I44.
    This is a question to ask your employer what you're allowed to fix on the truck.
    sawmill Thanks this.
  3. ExOTR
    ExOTR Windshield Chipper Extraordinaire
    Jan 23, 2013
    1,706
    Thanks Received:
    1,893
    Fort Worth, Tx
    Some small outfits will train you to check and adjust brakes, but megas will likely fire you for attempting any maintenance aside from checking oil/coolant levels, replacing lights, and a fuel filter(most won't even let you replace a filter). Huge liability to let an non certified person adjust anything safety related.
    Dominick253 Thanks this.
  4. Aarrons
    Jul 13, 2015
    242
    Thanks Received:
    75
    Thanks, I would like to know how much mechanichal stuff you are forced to do
  5. ExOTR
    Jan 23, 2013
    1,706
    Thanks Received:
    1,893
    Fort Worth, Tx
    Forced? Checking oil and coolant as part of your pretrip, and replacing lights that are within easy reach. They are not going to expect you to change out a trailer clearance light 13ft off the ground, but replacing a headlight that takes 25sec would probably be done by the driver. You don't want to wait 2hrs for a service truck to replace something you can do quickly with only a screwdriver.
    mindes Thanks this.
  6. TigerShark
    TigerShark Medium Load Member
    Nov 5, 2015
    454
    Thanks Received:
    329
    My rule of thumb. If i can do it in under an hour, fix it keep moving. If it's over 2, I start my breakdown pay and say forget it, sleeper time.
    Brettj3876 and BostonTanker Thank this.
  7. Moose1958
    Moose1958 Road Train Member
    Dec 17, 2010
    15,174
    Thanks Received:
    33,416
    Williesburg, Virignia
    This is hard to put into words but I think you need to know enough about the truck that you can give your company a general idea if you have a breakdown. Things like a blown turbo or a bad injector. Don't get too concerned with this because after a few years and experiences you will learn.
    TigerShark Thanks this.
  8. TigerShark
    Nov 5, 2015
    454
    Thanks Received:
    329
    Like when you tell the mechanic it's a injector and he argues and argues....2000 miles away
  9. blairandgretchen
    Dec 9, 2011
    13,380
    Thanks Received:
    71,946
    South west Missouri
    Your full pre trip duties, and checking and adding fluids as needed.
    As said before, most places don't want you fooling with much else outside your job duties.
    David_Simpson Thanks this.
  10. Moose1958
    Dec 17, 2010
    15,174
    Thanks Received:
    33,416
    I blew an injector a while back. I got out and took a flashlight and looked into my fuel tank. I saw the air bubbles coming from the bottom. The mechanic I spoke too asked me why I felt it was an injector and did it in a condescending way. Thankfully I was able to drive the truck a few miles to an international dealer who fixed it.
