How to shift 18 speed? When And how do you Drive it as A 18 speed, 13 speed and 9 speed
Discussion in 'Questions From New Drivers' started by Catrachotrucker, Jul 26, 2020.
  1. speedyk
    speedyk Road Train Member
    Apr 8, 2015
    1,837
    Thanks Received:
    2,470
    One thing to learn at first, when you normally go over to your knee for 6th, just go up to where 7th would be on a 10.
    Use the throttle to keep the drivetrain loose when splitting, you can preselect going up, but doing it going down might result in an unintended downshift.
    "Down for up, up for down"
    Splitting the low end is really useful in stop and go traffic, you can find a perfect speed to keep moving.
    You will not miss anything about a 10, and you will likely regret every second you had to use one.
    Brettj3876 and Kyle G. Thank this.
  2. jamespmack
    19,993
    Thanks Received:
    215,863
    Am the only on to say, It shifts like a manual transmission reguardless of the amount of gears. Just different pattern.
  3. kemosabi49
    Jan 13, 2013
    10,697
    Thanks Received:
    45,957
    SW Arkansas
    I drove a 13 for a long time. When I started in tankers I was put in a 10 speed. Never had been in one before. When I went to high range, I was so used to the 13 I wasn't going over by my knee to hit 6th. Kept trying to go straight to 7th. I had to concentrate when I changed lo to hi and back for a few hours until it became normal. Never liked the 10 either.
  4. Kyle G.
    Kyle G. Road Train Member
    Jan 23, 2016
    3,861
    Thanks Received:
    20,291
    Eastern Iowa
  5. LameMule
    LameMule Road Train Member
    Jan 19, 2020
    1,147
    Thanks Received:
    7,404
    Montana
    RTO vs RTLO
    Brettj3876 Thanks this.
  6. skellr
    skellr Road Train Member
    Jul 17, 2011
    8,737
    Thanks Received:
    12,187
    The Village, Portmeirion
    I would start out by driving it like a 9spd, unless you are heavy beyond a legal load, you can start splitting when it starts to bog down or in the hills.
    You'll be fine, just takes some practice.
    I agree.
    And just because you can split gears doesn't mean you should, or need to.
  7. jamespmack
    19,993
    Thanks Received:
    215,863
    I agree with that too.
    Speed_Drums Thanks this.
