I have a volvo VNM 630 2012 with 564000 miles, is showing RETARDER TEMPERATURE HIGH anyone know it
Discussion in 'Volvo Forum' started by AGalvis, Jul 8, 2019.
  1. AGalvis
    AGalvis Bobtail Member
    Jul 8, 2019
    Thanks Received:
    I have a volvo VNM630, 2012, 564000 miles, I have a RETARDER TEMPERATURE HIGH, on my screen, anyone can help me.
  2. boneebone
    boneebone Road Train Member
    Mar 13, 2009
    2,295
    Thanks Received:
    2,366
    Check the oil level in the transmission, it could be low causing high temperatures.
    AGalvis and x1Heavy Thank this.
  3. x1Heavy
    x1Heavy Road Train Member
    Mar 5, 2016
    34,017
    Thanks Received:
    42,135
    White County, Arkansas
    And check your oil pressure as well in both engine and transmission. If they agree along with your axles you are ok. Something is going on. Im inclined to follow Boneebone here for sure.
    In my day we use Jacobs over the Pistons the hard way. Never had em fail unless the fuse box got loose somehow.
    In the meantime turn off the retarder and get to a shop where you can safely check the oil levels.
    AGalvis Thanks this.
  4. Tb0n3
    Tb0n3 Road Train Member
    Oct 5, 2012
    4,538
    Thanks Received:
    9,013
    Earth
    The only retarder that can get hot is the euro electric eddy retarders. They dump the heat in heatsinks. Otherwise it wouldn't make sense to me why it would warn of that.
    Retarder (mechanical engineering) - Wikipedia
  5. Newto Trucking
    Newto Trucking Medium Load Member
    Dec 26, 2013
    359
    Thanks Received:
    225
    NE Illinois
    What engine is in your truck and the transmission ??? Do you have error codes??
  6. AGalvis
    Jul 8, 2019
    Thanks Received:
    I have a volvo engine D11 and volvo transmission, my truck is automatic with I Shift.
    I don't have any error code
  7. Tb0n3
    Oct 5, 2012
    4,538
    Thanks Received:
    9,013
    Earth
    It looks like it's an electric retarder in the transmission. Could be a dirty heatsink, clogged oil cooler, or something of that sort. It could just be that you're using it too much for it's specifications.
    Could just be a simple hydraulic retarder.
  8. nasriza
    nasriza Road Train Member
    Feb 1, 2013
    2,397
    Thanks Received:
    2,070
    Chicago, IL
    Would it be possible you have a factory installed pto Set up and have left it on not knowing. and thats why its calling retarder temp high.
