installed my own EGR today...easy as cake
Discussion in 'Volvo Forum' started by sbaumann14, Mar 25, 2017.
  1. sbaumann14
    sbaumann14 Road Train Member
    Sep 1, 2010
    1,226
    Thanks Received:
    1,422
    Rhinelander, WI
    if you have one of your eGR's go down on you, replace it yourself. I did. took me 2 1/2 hours and 3 beers. so save yourself some money and do it yourself.
    Justrucking2, Johny41, tucker and 2 others Thank this.
  2. xsetra
    xsetra Road Train Member
    Aug 21, 2011
    5,160
    Thanks Received:
    7,092
    Should a took more than 3 beers! I'll take it to a shop. I get at least a 6 pack that way. Haha.
    Is always good to save a bit of money.
  3. sbaumann14
    Sep 1, 2010
    1,226
    Thanks Received:
    1,422
    Rhinelander, WI
    yeah, was 1st one I had to replace in about 4 years due to the delete kit I have on it
  4. nasriza
    nasriza Road Train Member
    Feb 1, 2013
    2,398
    Thanks Received:
    2,074
    Chicago, IL
    you did relatively quick for never having done one before. just make sure you ran all the wires properly that's the number 1 cause of egr going bad. no matter what you did to the valve if the wires short out it will derate and throw a code almost always unless a lot of programing has been done
  5. sbaumann14
    Sep 1, 2010
    1,226
    Thanks Received:
    1,422
    Rhinelander, WI
    Yep, did that, and thanks for the help in identifying the #1egr. Very easy to do. Hardest part was taking off alternator to get to the plug behind it.
  6. nasriza
    Feb 1, 2013
    2,398
    Thanks Received:
    2,074
    Chicago, IL
    its not usually that bad of a job.
  7. visoiuvlad
    visoiuvlad Light Load Member
    Sep 5, 2014
    121
    Thanks Received:
    63
    Where did you bought the kit?
