Installing a fridge in our new truck?
Discussion in 'Ask An Owner Operator' started by Whiteline64, Sep 8, 2018.
  1. Whiteline64
    Whiteline64 Light Load Member
    May 5, 2016
    189
    Thanks Received:
    177
    Atlanta,GA
    Basically the question is when we get our truck , we want to remove the cabinet behind the drivers seat and install a fridge ..
    a little bigger one than the usual ones.
    How do you power this fridge ? What is recommended to install it ?
    Thank you in advance for any suggestions .
  2. LoSt_AgAiN
    LoSt_AgAiN Heavy Load Member
    Sep 7, 2018
    766
    Thanks Received:
    3,855
    Are you a company driver or O/O ? You will need to install a power inverter to power a larger fridge. And somehow mount it or strap it down to keep if from bouncing around the cab in case of an accident etc.
    Whiteline64 Thanks this.
  3. Jeremy1
    Jeremy1 Bobtail Member
    Mar 16, 2018
    36
    Thanks Received:
    12
    3000 watt inverter could go bigger but that's what we ran a dorm fridge with in our old truck and no problems
    Rounded_nut and Whiteline64 Thank this.
  4. supersnackbar
    Aug 19, 2007
    19,793
    Thanks Received:
    50,794
    Your Town, USA
    I ran a dorm fridge on a 2500 along with a tv, dvd, sound bar and a 700 watt microwave. A regular fridge takes less juice than you think...the startup of the compressor is the biggest power draw. (I had mine strapped to the top bunk...minus the mattress)
  5. Whiteline64
    May 5, 2016
    189
    Thanks Received:
    177
    Atlanta,GA
    Yes , O/O .. buying a truck very soon ! Thx ..
  6. Rideandrepair
    Aug 8, 2015
    17,436
    Thanks Received:
    56,554
    I’m in the same process. Have 2 inverters 1000 and 1500 would like to use 1 for fridge and 1 for microwave. Wondering if 1000 will handle very small fridge. Thinking of 1500 for microwave (600) watt and coffee maker etc can use one at time.I know you can’t wire them together to make more power. But would like to run 1 hot and 1 ground under bunk and connect both inverters and maybe a third 600 watt at that one point under bunk. What guage wire to use?
  7. Eddie85
    Eddie85 Bobtail Member
    Sep 8, 2018
    26
    Thanks Received:
    12
    1000 will be fine as long as it's 1.7 cu. Ft. Or smaller and energy star rated. You don't want the inverter working at Max. Capacity at any given time as it lowers it's lifespan. 1500 may be too small for the coffee maker for this reason. 2000 may be a little overkill but a better fit. And in either case never run both the microwave and the coffee maker at the same time. As far as what wire to use. It'll vary a bit with the efficiency of the inverter but IMHO 2 or smaller would always be a good bet. Don't forget to fuse it to reduce risk of fire. And if you only want 1 connection at the battery your gonna need power distribution & ground junction blocks since it's better to have them in parallel than in series.
    Rideandrepair Thanks this.
  8. Cottonmouth85
    Cottonmouth85 Bad Influence
    May 3, 2012
    2,637
    Thanks Received:
    8,701
    Floresville, Tx
    What type of truck?
  9. Snakeschasingcars
    Snakeschasingcars Heavy Load Member
    Mar 22, 2018
    743
    Thanks Received:
    1,570
    I did the same with my top bunk. Slid in a folding table over a few 2x4 cut to size. Makes a great counter top.Straped everything up there. Microwave. Toaster. I use a 3 step stepping ladder to access everthing easly and work off the counter top.
    But if i was allowed to remove the shelving behind the passenger seat i would and put one those taller friges/freezer there and strap the microwave on top of that. There easly enuf space with seat up. But they would be upset if i start removing #### from there new truck lol. But the fridge/freezer i got is fairly large. 3.5 cu feet i think.
    Rideandrepair and Whiteline64 Thank this.
  10. Whiteline64
    May 5, 2016
    189
    Thanks Received:
    177
    Atlanta,GA
    Freightliner Cascadia 2015
