LOGGING QUESTION.
Discussion in 'Questions From New Drivers' started by allen731, Apr 4, 2016.
  1. allen731
    allen731 Light Load Member
    Apr 4, 2016
    59
    Thanks Received:
    10
    Say, I've dropped my last load and I am clear to drive home. How would I electronically log that? Thanks
  2. 426yankee
    426yankee Light Load Member
    Jan 23, 2016
    110
    Thanks Received:
    115
    Charlottesville,VA
    Log the on-duty not driving for the unload, back to line 3 for the drive home, then line 1 for the home-time
    pattyj Thanks this.
  3. pattyj
    pattyj Road Train Member
    Jul 19, 2008
    22,474
    Thanks Received:
    20,137
    Sioux City,ia
    Log it like any other day once you get home do post trip then put yourself on line one.Do not move the truck otherwise that will disturb your logs if your on elogs and put u on line 3 or 4.
  4. Moosetek13
    Moosetek13 Road Train Member
    Nov 1, 2010
    14,685
    Thanks Received:
    18,458
    Burnsville, MN
    If my home time is long enough I might take out the truck to run errands, but I'll make sure I have time for a 34 first.
  5. allen731
    Apr 4, 2016
    59
    Thanks Received:
    10
    Thanks alot!
  6. Old school 362
    Old school 362 Medium Load Member
    Mar 6, 2016
    392
    Thanks Received:
    249
    Pensacola Fl
    Sign out of system . Save you in the long run. Prevents you from messing with your restart. And also in the future prevents the shop from from messing with your hours. As they fix your truck.
    pattyj Thanks this.
  7. Pmracing
    Pmracing Road Train Member
    Jan 28, 2011
    6,354
    Thanks Received:
    3,178
    Arlington Heights, IL
    Who's truck is it? Who is restricting your off duty driving?
    I am a company driver and they limit OD Driving to a half hour, for normal company drivers. I fall under a different category since I do not have a terminal, I park at home every night.
    I am no scholar on all DOT regs, is there a rule limiting off duty driving on a 34? If one is unencumbered by company regulations...
    Mikeeee
  8. pattyj
    Jul 19, 2008
    22,474
    Thanks Received:
    20,137
    Sioux City,ia
    hmmm never thought about doing that
  9. Old school 362
    Mar 6, 2016
    392
    Thanks Received:
    249
    Pensacola Fl
    Yep when I was a company driver. I learned the hard way. Keep in mind the company still has gps on that truck. So I would not drive it ounce parked. But helps you if you need to move it a short distance
  10. w.h.o
    w.h.o Road Train Member
    Jan 10, 2011
    3,583
    Thanks Received:
    4,094
    Chicago, il
    It doesn't disturb your 34, I done it before and still got my reset
    Signing off before getting truck service prevents the shop guys from running your log. But signing off to drive the truck will notify your company.
    I had a new qc computer installed and the shop said don't log in for 2 hours. So I when on paperlog and drove without signing in. My company got notify, my manager got notify, and apparently they thought someone stole truck
    Old school 362 Thanks this.
