My Detroit 60 will drop engine temp to 50 idling in cold weather.
Discussion in 'Freightliner Forum' started by TOMBSTONE1954, Mar 2, 2014.
  1. snowwy
    snowwy Road Train Member
    Jul 6, 2009
    20,553
    Thanks Received:
    13,281
    coolant mix ratio wouldn' t have anything to do with it. even straight water will run the same.
    i usually drop to 170 when idling that cold. the fan don't ever come on. your heater core works just like the radiator. when it's that cold. the heater alone will cool the truck down.
    i would do a ecm check. see if the ecm is reading the same as the gauge. your sympton is typically a bad thermostat. but like others have said. it could be the gauge sensor.
  2. TOMBSTONE1954
    TOMBSTONE1954 Bobtail Member
    Mar 2, 2014
    12
    Thanks Received:
    8
    I appreciate all the replies. I never had a problem like this one and the tips are helpful. I will get the thermostat changed and the temp sensor when I get back home. Also need to have Freightliner idle me up to around 850 and check the emc... Thanks
  3. EZX1100
    EZX1100 Road Train Member
    Aug 18, 2012
    4,017
    Thanks Received:
    5,711
    i changed both thermostats, no more cardboard, good heat
    cost $85 parts and 30min labor (my labor)
  4. Rupi0151
    Rupi0151 Bobtail Member
    Jun 2, 2019
    Thanks Received:
    Hamilton
