need help and advice. injectors 3406e!!!!!
Discussion in 'Peterbilt Forum' started by double brew, Apr 28, 2015.
  1. double brew
    double brew Light Load Member
    Mar 7, 2015
    76
    Thanks Received:
    20
    As the title states, I have a few injectors sticking on my truck. I just bought it and got my first load on it last night. I called the place I bought the truck from and they said they would buy only 3 Delphi injectors. Anyone know if these are worth a ####? He can get them for 379 each. I'm at 550/1850 for power and might be getting a little bigger turbo (non wastegated 75mm borg warner) before too long. Any advice? On part numbers? c15s? The motor is a 99 1lw.
  2. Klleetrucking
    Klleetrucking Medium Load Member
    Dec 11, 2010
    378
    Thanks Received:
    346
    S.C.
    How many miles on the current set of injectors? $379 sounds pretty cheap but that doesn't answer your question if Dephi's are any good, I personally try to use Cat stuff myself. I did 6 injectors on my '03 C 15 last year (1million miles) $4500 but that included several dyno pulls and an ECM clean up and uprate.
    IMO if you can swing it put 6 injectors in, part of the labor is already there and if they're a decent shop they should run the entire O/H even putting in 3.
    Good Luck!
  3. EHB
    EHB Medium Load Member
    Apr 26, 2011
    491
    Thanks Received:
    209
    Newfoundland
    Where did you get the tune up done too?
    Sound like they went all out to fine tune the output.
  4. maggard359
    maggard359 Medium Load Member
    Nov 20, 2013
    476
    Thanks Received:
    413
    Florida
    I would try to replace with 10r8502. They run a little
    hotter but you will be happy. I have them in one truck with 6nz 550 brakesaver file running SDP acert block and that truck pounds the ground, good mileage and stays cool, rolls black smoke on take off. I read your other post and would not surprise me if your injector harness is your problem. Cutout can give false readings if wiring is junk. You can switch injectors and see if problem follows injector or stays in cylinder. Electro diesel in laredo Texas will exchange 300 each and I have had very good success with them, I have no past experience with a bosch brand injector other than what's in my land rover and it's doing fine.
  5. Klleetrucking
    Dec 11, 2010
    378
    Thanks Received:
    346
    S.C.
    Antrim Diesel
    Greencastle,Pa.
  6. truck2152
    truck2152 Bobtail Member
    Apr 29, 2015
    16
    Thanks Received:
    7
    I had a cat do the same I found that the injector that goes in a ford 105 dollars will work but
    U may also try hotshot secret to stop sticking injectors
  7. double brew
    Mar 7, 2015
    76
    Thanks Received:
    20
    How steady should fuel pressure be? Between 1-2 lbs under load?
  8. 062
    062 Road Train Member
    Oct 20, 2013
    6,335
    Thanks Received:
    33,976
    What maggard359 said check your harness. Guy I'm leased to had one chew up two injectors in same hole. They found a rubbed wire in harness,where it turns to the motor.
