Oil bypass systems anyone running one?
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Mad dog logistics llc, Dec 21, 2022.
  1. Mad dog logistics llc
    Mad dog logistics llc Light Load Member
    Jan 13, 2014
    152
    Thanks Received:
    37
    I have a Cat 3406 5ek that Im going to rebuild this spring and have been seeing a lot of info on Oil bypass systems but dont know anyone running them.
    Anyone out there have one of these systems on your truck? Which one?
    How many miles since oil change?
    How often do you change the filters
    Do you still change regular oil filters the same amount of miles or do you wait a little more?
  2. TruckerPete1990
    TruckerPete1990 Road Train Member
    Jul 16, 2012
    8,623
    Thanks Received:
    5,381
    Bentonville Arkansas
    I run the OPS system its a little pricey but worth it! I do an A & B service. Every 20k I oil sample wait for it to come back if good then i change the oil bypass and grease. Every 40k I sample if good change engine and bypass filter. Reason I wait for oil sample as no point in wasting a set of filters if something comes back bad.
    Personal I never go above 100k on oil even if it's showing good.
    Siinman and Mad dog logistics llc Thank this.
  3. GYPSY65
    GYPSY65 Road Train Member
    Nov 16, 2012
    1,957
    Thanks Received:
    5,264
    SW FLA
    I’ve looked into getting one
    Seems the cost per oil change Vs this is about the same but it’s the keeping of the garbage out of the engine that seems like the reason for one
    Is that what you’ve found?
    Not any cheaper per mile but less junk in the engine. Especially with Dec?
  4. TruckerPete1990
    Jul 16, 2012
    8,623
    Thanks Received:
    5,381
    Its cheaper cost me about $150 every other service with 2 filters and 1 oil sample otherwise its $100 so its way cheaper then a oil change. Last oil change i had was like $450
  5. beastr123
    beastr123 Road Train Member
    Jan 2, 2014
    2,916
    Thanks Received:
    23,893
    Moose Jaw SK CAN
    I used the FS2500 from Filtration Solutions in Olathe KS
    The elements are $36 each and I changed mine at 15k with samples at 10k and full changes at 30k or 45k depending on samples.
    My 12.7l 470 went to 2.3m miles when I dropped a lower rad hose at -40f and started using coolant.
  6. jamespmack
    20,033
    Thanks Received:
    216,320
    I have a ops used with all parts and extra filters. Pick up Northwestern Ohio. Make a offer.
    Siinman Thanks this.
  7. blairandgretchen
    Dec 9, 2011
    13,632
    Thanks Received:
    74,071
    South west Missouri
    Same story here but on the N-14.
    I found the FS system a bit messy on the filter changes, and the price increased.
    I went with Amsoil EaBp with gallon spin on filters - change every 20-30k - sample every 10k, change oil by sample quality, typically every 25-35k.
    Siinman and beastr123 Thank this.
  8. beastr123
    Jan 2, 2014
    2,916
    Thanks Received:
    23,893
    Moose Jaw SK CAN
    FS2500 now has spin-on at 60 per piece
    blairandgretchen Thanks this.
  9. blairandgretchen
    Dec 9, 2011
    13,632
    Thanks Received:
    74,071
    South west Missouri
    Not bad - I think I'm giving $43 a piece for the Amsoil.
    I think they all work about the same, I like the assurance of multiple filtration removing potentially harmful deposits.
    I think the later engines incorporated double filters with a finer micron rating for one of the filters to essentially perform the same function as the bypass systems - I recall ODFL going to 50k oil intervals around 2013 with the DDEC 15 they were buying.
    Spin on is a lot less messier than the cotton cartridges FS had prior.
    beastr123 and Siinman Thank this.
  10. Luwi67
    Luwi67 Heavy Load Member
    Oct 24, 2012
    749
    Thanks Received:
    484
    Long island
    I've been running gulf coast filters GCF2 since 2004 on my 6TS 3406E. sample every 10k change filters every 12k, way, Way easier than doing an oil change. With the regular sampling I know exactly what's going on in my engine and we can watch a pattern develop if it does.
    GYPSY65 Thanks this.
