Out of frame rebuild
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by jbob1, Dec 3, 2019.
  1. jbob1
    jbob1 Light Load Member
    Sep 22, 2017
    68
    Thanks Received:
    91
    Gonna start looking for some rough estimates for an outa frame rebuild on a 12.7, figuring on replacing air compressor with it. What would be a ballpark figure to consider?
    Rideandrepair Thanks this.
  2. jbob1
    Sep 22, 2017
    68
    Thanks Received:
    91
    This would be on a 2003 pre egr motor that I currently own in a Columbia with about 1.7 mil. on it that was inframed at 900k mi
  3. AModelCat
    29,393
    Thanks Received:
    161,330
    Depends how much you're going to do to it.
    Oxbow, pushbroom and spsauerland Thank this.
  4. spyder7723
    spyder7723 Road Train Member
    Mar 31, 2013
    15,471
    Thanks Received:
    25,077
    sarasota, fl
    Side question What else besides a bad crank and line boring would require pulling the block out?
    Oxbow and AModelCat Thank this.
  5. jamespmack
    20,033
    Thanks Received:
    216,320
    At that mileage I would prefer to deck the block top and bottom to square it up. I know this is not a normal practice. But once you square up a seasoned block, you normaly will never do it again.
    Most blocks at a million miles have a twist to them.
  6. spyder7723
    Mar 31, 2013
    15,471
    Thanks Received:
    25,077
    sarasota, fl
    You can deck the top with it still in the truck. Not sure why you would deck the bottom. Or for that matter how the bottom could wear off square. Or are you talking about line boring it for the crank and grinding the main bearing caps?
    Rideandrepair, Oxbow and jamespmack Thank this.
  7. jbob1
    Sep 22, 2017
    68
    Thanks Received:
    91
    Not quite sure what all I want to do with it yet, my situation is I got this Columbia ( which I've run for 10 yrs), it started pushing oil out the dipstick under load( won't do it bobtailing). I bought a 2012 Coronado glider, love the truck but it's a Fitzgerald 12.7 with 530k mi, runs good, ####ty fuel mileage ( avg 5.8) but I know a couple of yrs down the road I gonna have to in frame it( unknown parts in Fitzgerald motor), so maybe keep motor from Columbia and outa frame it and know what's in it
  8. jamespmack
    20,033
    Thanks Received:
    216,320
    Nope. After a million the block has a twist. Take some of the top and bottom to square everything up. It will be the best block you ever have. New cast block and all the heat cycles/ torque, its twisted. You square it up. And now that cast iron is "seasoned" thru that many heat cycles. Tru that block up top and bottom and it will stay square. More for a higher end build. Not your Chicago Can hauler. Some guys with cats have a head gasket problems after a rebuild with correct liner protrusion. A N14 after a million should be line bore. I suspect if you picked at them. They all could use it. But I would not recommend rebuilding a N14 for HP without it.
    Dino soar, Dave_in_AZ, Oxbow and 5 others Thank this.
  9. spyder7723
    Mar 31, 2013
    15,471
    Thanks Received:
    25,077
    sarasota, fl
    I guess what I'm not understanding is what in the bottom could need squared. The only thing on the very bottom of a 12.7 is the oil pan bolt holes. That's why I thought you meant the bearing caps and cap mating surfaces, but that's standard procedure with a line bore
    Rideandrepair and jamespmack Thank this.
  10. jamespmack
    20,033
    Thanks Received:
    216,320
    Ok, I'll try and explain it different. Imagine a twisted pretzel. The whole block has a twist. I'm talking square top to bottom. Not just flatting top and bottom. Geometry my boy.
