Padlock keyhole clogged with sand/salt?
Discussion in 'Experienced Truckers' Advice' started by PE_T, Jan 15, 2019.
  1. PE_T
    PE_T Road Train Member
    I have this padlock under my trailer that I cannot open. It’s a sturdy one too, as well as the chain. I can’t cut them with my small bolt cutter. I think sand/salt got into the keyhole, so the key won’t go in. I sprayed some water, but nothing.
    I know I should have covered the lock, but it’s too late now. If I can’t get it opened, I will have to borrow a big bolt cutter from a receiver to cut a chain link. The padlock is tougher than the chain.
  3. STexan
    STexan Road Train Member
    14,963
    29,160
    Oct 3, 2011
    Longview, TX
    All you can do short of buying a bigger pair of bolt cutters is buy a few cans of wd40 and use the red pipe to try and flood the garbage out but don’t expect too much. It’s the salts that creep deep into locks and ruin them internally. No “weatherproof lock” will work either if you run where they use stuff on winter roads.
    We don’t lock our chains up for this reason. You won’t be able to get to them when you need them.
  4. Powder Joints
    8,053
    8,546
    Sep 25, 2007
    Rosamond, SoCal
    WD40 or diesel fuel should clear it out, once clear cover it.
    Lepton1 and PE_T Thank this.
  5. pmdriver
    pmdriver Road Train Member
    2,338
    3,503
    Nov 14, 2017
    Big hammer and smack it a few times with all holes pointed down, add wd 40 all over.
    PE_T Thanks this.
  6. mitmaks
    mitmaks Road Train Member
    2,593
    2,115
    May 16, 2014
    Maybe use small propane torch to heat it up along with PB blaster
  7. gokiddogo
    gokiddogo Road Train Member
    8,786
    14,770
    Mar 5, 2012
    Ontario Canada
    If you have 2 wrenches of correct size you may be able to break it open. For this reason I carry 36" bolt cutters. Cut anything and has been useful in the past when I used those really heavy locks then experienced the same issue you're having now. I don't care for the round lock that claims it is bulletproof. Heavy lock deters most thieves anyway. No problems as of yet (knock on wood).
    Lepton1, Sirscrapntruckalot and PE_T Thank this.
  8. PE_T
    I know about that trick, but I am very certain the trick cannot be done on my padlock. It is tough. I got one of the toughest ones at Home Depot. I kind of regret it, but at least now I know that a regular bolt cutter cannot cut it. Not a chance. My bolt cutters barely left a mark. I was able to make a small dent on my chain, though.
  9. gokiddogo
    8,786
    14,770
    Mar 5, 2012
    Ontario Canada
    If you see someone using a big bolt cutter or one at a pickup or delivery ask to borrow it. Someone will have a set. Better than ruining a chain.
    I guess this means nobody can steal your chains now huh lol
    bigguns and PE_T Thank this.
  10. Powder Joints
    8,053
    8,546
    Sep 25, 2007
    Rosamond, SoCal
    I use two different depending on the trailer, 1 is the round ABUS lock and the other is the large weather resistant master lock, if the weather is bad , I wrap them in a sandwich bag, then wrap it in duc tape, easily removed keeeps them clean both look and operate like brand new and were purchased back in the early 2000's.
  11. Powder Joints
    8,053
    8,546
    Sep 25, 2007
    Rosamond, SoCal
    I also carry a extra air hose and a die grinder, have not found a padlock yet that the grinder won't open.
    91B20H8, Dino soar, slim shady and 5 others Thank this.
