Parasitic drain issue.
Discussion in 'Trucks [ Eighteen Wheelers ]' started by angelor, Jun 4, 2013.
  1. angelor
    angelor Bobtail Member
    May 22, 2013
    40
    Thanks Received:
    Starter ruined due to high voltage. I wonder if 24 volt machine which can be charged from truck engine 12 volt has something to do with this? I will checking that link.
  2. allan5oh
    allan5oh Road Train Member
    Jan 6, 2010
    1,557
    Thanks Received:
    556
    Winnipeg, mb
    positive wire touching the frame, etc..
  3. allan5oh
    Jan 6, 2010
    1,557
    Thanks Received:
    556
    Winnipeg, mb
    If you disabled everything and it's all going wonky I'd check the main starter cable from the batteries. It's probably rubbing on the frame above the batteries.
    angelor Thanks this.
  4. Ridgeline
    22,365
    Thanks Received:
    115,987
    OK because there is something mounted on the back end of the truck, try disconnecting that from the rest of the truck.
    The flashing of lights and so on may be the body computer freaking out, this truck is something else with all the modules.
    I don't see why you would get 7.8 volts, you need an amp meter - the power probe is good but they need to add a 100amp meter feature to it.
    Also so you understand the complexity of this mess - the M2 - here are a couple links to electrical info for the M2. These explain a little about the modules and what wiring, fuses and so on are on the truck.
    This is about the 2007 M2
    https://secure.freightliner.com/acc...07 Electrical Body Builder Manual Rev New.pdf
    This is about the 2010 M2 - it still helps if the chassis was uprated
    https://secure.freightliner.com/acc...0ElectricalModels-M2106-M2112-108SD-114SD.pdf
  5. angelor
    May 22, 2013
    40
    Thanks Received:
    Ridgeline you are the person!!! I got more info from that link than anything from freightliner. Thanx a million.
  6. angelor
    May 22, 2013
    40
    Thanks Received:
    All the grounds were coated green. Pulled starter to get tested and it was inoperable due to high voltage and corrosion everywhere. Bought a big tub of bulb grease drilled holes in bottom of all turnsignals to drain water from rain out.
  7. angelor
    May 22, 2013
    40
    Thanks Received:
    Changed starter and now it won't crank is there a way I could have miswired? There is only 2 posts 1 little and one big which has an adapter on it for the other 2 wires that are big. Will be checking for voltage to starter next. Read something about a fusebox in the VIM what is that and where is it?
  8. angelor
    May 22, 2013
    40
    Thanks Received:
    bought cheap tester at menards thinking it would measure amps, but could only get ohms. 150 ohms on a 12 volt circuit= 14 amps. Also got exact same reading when i went directly to battery itself. Hope this helps.
