Peterbilt 387 2010 speed sensor eaton fuller transmission broke off when replacing.
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Big Lou, Sep 4, 2015.
  1. Big Lou
    Big Lou Light Load Member
    Aug 15, 2013
    155
    Thanks Received:
    25
    Tampa, Florida
    Hey guys need help with my speed sensor it broke apart when trying to get it out! It is stuck in the housing. I am afraid to drill it because all the material from drilling will go into the transmission. Any advice.
  2. blairandgretchen
    Dec 9, 2011
    13,376
    Thanks Received:
    71,892
    South west Missouri
    I was wondering either - really strong magnets next to it as you drill, OR really strong shop vac - or both?
  3. AModelCat
    29,140
    Thanks Received:
    158,346
    I've had good luck with heavy grease on the drillbit. Drill a little bit, clean off the grease and chips, fresh grease, keep drilling.
  4. 062
    062 Road Train Member
    Oct 20, 2013
    6,201
    Thanks Received:
    33,404
    Do you have another port on the side you could use?
  5. baha
    baha Road Train Member
    Jul 25, 2013
    4,137
    Thanks Received:
    2,836
    ga
    Most new ones are made of plastic you just have to dig it out with a sharp tool, the center will pull out with some pointed nose tool.
    blairandgretchen Thanks this.
  6. DoubleO7
    DoubleO7 Road Train Member
    Aug 21, 2015
    1,532
    Thanks Received:
    1,597
    Southern Illinois
    A set of sharp mechanics picks may help you out.
  7. Cottonmouth85
    Cottonmouth85 Bad Influence
    May 3, 2012
    2,637
    Thanks Received:
    8,701
    Floresville, Tx
    I agree with the grease if you drill, or turn the truck upside down so the shavings fall out. I also agree with the pick. Get a little hammer and see if you can't tap it lightly to get it started backing out.
  8. Big Lou
    Aug 15, 2013
    155
    Thanks Received:
    25
    Tampa, Florida
    this is the most frustrating thing this sensor is plastic and a magnet. whoever did this design is an idiot the transmission obviously gets really hot andand is like welded in the port with the heat
  9. Cottonmouth85
    May 3, 2012
    2,637
    Thanks Received:
    8,701
    Floresville, Tx
    Yeah.... gotta wonder what those 'highly educated' engineers are smoking sometimes. Have you made any progress on it?
  10. Alaska76
    Alaska76 Road Train Member
    Jan 20, 2014
    1,228
    Thanks Received:
    1,653
    Inland Empire, WA
    Been there, done that. Magnets are darn near impossible to drill. Get a torch, some vice grips, a HEAVY wire; heat the wire and insert into the plastic multiple times, enough to create a lot of relief around the magnet so that you can insert some pliers or a hooked tool to remove the remainder. When you insert the replacement part be sure to coat it with anti-seize or silicon grease to prevent this from happening again.
    Harley2e, blairandgretchen and truckon Thank this.
