Pro star intl 08 odometer stuck in km's
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Robbman, Feb 25, 2012.
  1. Robbman
    Robbman Bobtail Member
    Feb 11, 2011
    46
    Thanks Received:
    How do i switch it back to miles?
  2. Dutch
    Dutch Light Load Member
    194
    Thanks Received:
    58
    Commiefornia
    hold down the trip reset
  3. Hardlyevr
    Hardlyevr Road Train Member
    Jul 30, 2009
    3,270
    Thanks Received:
    2,540
    Mapleton Depot,PA
    You have to go back to Canada and come back into the USA again, and them hopefully it will change that time! :biggrin_25526:
    Sorry, I couldn't help myself.
  4. Robbman
    Feb 11, 2011
    46
    Thanks Received:
    Ok i just got back from canada and tried the trip reset knob, still nothing. Ive always wanted to drive a truck in australia, maybe ill ship it over there and give it a try.
  5. Hardlyevr
    Jul 30, 2009
    3,270
    Thanks Received:
    2,540
    Mapleton Depot,PA
    I would NOT try that, you might end up with the steering wheel on the wrong side!
  6. Heavyd
    Heavyd Road Train Member
    Feb 4, 2009
    7,768
    Thanks Received:
    6,207
    The micro switch inside the cluster for the reset knob is probably messed up. Try to press down with the cab really cold, or really hot, and try hold it with different pressure to see if that switch will register.
  7. Scrapper
    Scrapper Light Load Member
    Jan 19, 2010
    289
    Thanks Received:
    83
    Nashville, AR
    Not same thing...but we have an international...99 model Eagle...that the odometer will not read on...says "error". Speedo/ Tach and everything else works. Connections and circuit boards all seem to be good. Didn't see any broken solder joints or burnt spots. We have been using a hubometer...and its hard for the driver when going from state to state with the others....when he has to stop and they don't. Have any of you ever run into this?? Why couldn't international use a speedo and tach like a Kenworth. Fixed two of them today. lol
  8. Shaggy76
    Shaggy76 Heavy Load Member
    Feb 22, 2012
    831
    Thanks Received:
    307
    Orlando, FL
    Remove the plug to the ECM. Wait approx 2 minutes and plug back in. It should be back on miles. Other option is remove the big fus on the battery. That is ECM protection fuse. Take a shower or something and come back. Give it time for the ECM to lose all power. It will do it then as well.
    Let me know if this helps.
