Problems with Recaps, should I recap or buy new?
Discussion in 'Ask An Owner Operator' started by Matthew77, Sep 13, 2018.
  1. Matthew77
    Matthew77 Bobtail Member
    Sep 13, 2018
    Thanks Received:
    The treads on my trailers tires are starting to wear real thin and I'm looking at whether or not to recap them or just bite the bullet and get some new ones. I'm new to this and was wondering, if I recap what are common issues and problems I can expect? Would you guys advise it?
    Thanks,
    Matthew
  2. Derailed
    Derailed Road Train Member
    Dec 10, 2008
    2,383
    Thanks Received:
    2,657
    Upstate NY
    For not a whole lot more you could put a set of Roadmasters or Yokohamas on there and feel a bit more at ease on those hot summer days. I know some guys have good luck with caps. Key obviously is to be on top of your tire pressure at all times. I was just never a fan myself.
  3. RSB34
    RSB34 Light Load Member
    Feb 9, 2013
    277
    Thanks Received:
    198
    ny.
    For the price of cheaper new tires I buy new. With caps and with new but not as much. You need to keep your tire pressures up. If you don't the sidewall flexes too much and they blow. When it's hot out I don't run caps more than 60-65mph when it's hot speed builds heat heat make gators on the rd.
  4. Midwest Trucker
    Aug 31, 2018
    5,911
    Thanks Received:
    21,378
    If they started as virgins then have someone like Goodyear cap them but only if you get your tires back. I understand that could be hard if you have just one set.
    If you get random tires back then go with new virgin set and have your virgins capped for the next rotation. Only problem with caps if you know their history is rarely if you turn extremely tight, it can roll the cap off the casing.
    If you run coast to coast just get new ones IMO.
    jammer910Z Thanks this.
  5. baha
    baha Road Train Member
    Jul 25, 2013
    4,137
    Thanks Received:
    2,836
    ga
    If like you said their recaps now the tires may not be able to get caped another time?
  6. I glide 47
    I glide 47 Road Train Member
    Jun 3, 2017
    1,426
    Thanks Received:
    1,523
    I don't run recaps not on my truck or trailer or logbook. But if you do air pressure is everything. Also heard Michelin having a problems with theirs now. Good luck
    CorsairFanboy Thanks this.
  7. jammer910Z
    jammer910Z Road Train Member
    May 28, 2015
    2,446
    Thanks Received:
    6,522
    Caps are not a problem IF they're made on good casings.
    Air pressure is the killer.
    Guys don't check it.
    That's what causes failures.
    Low pressure builds heat... KAPOW.
    Then the cap gets the blame.
    Even virgin tires will pop if you run them underinflated.
    I get trailers all the time with tires at 60# of pressure of less.
    Who knows how long the other idjits have been dragging it like that.
    It's not flat, right?
    Justrucking2 and exhausted379 Thank this.
  8. 6wheeler
    6wheeler Road Train Member
    Aug 30, 2009
    2,696
    Thanks Received:
    4,774
    Recraps are an accident waiting to happen.
  9. Ridgeline
    22,453
    Thanks Received:
    117,510
    I never ever buy recaps, I have had too many cars fixed because of them.
    tommymonza and Justrucking2 Thank this.
  10. magoo68
    magoo68 Road Train Member
    Jun 11, 2011
    3,393
    Thanks Received:
    5,385
    st malo mb canada
    Caps are too expensive to run if you’re paying attention and tracking fuel costs virgin tires are practically free compared to caps just on fuel savings alone
    dunchues, tommymonza and I glide 47 Thank this.
