Reefer overheating!! Help
Discussion in 'Refrigerated Trucking Forum' started by Jennyspete, Jul 21, 2020.
  1. Jennyspete
    Jennyspete Light Load Member
    Apr 3, 2010
    71
    Thanks Received:
    47
    ma
    Ok I have a load on so this is critical. SB 210 low coolant level, engine temp high. Forced low idle.
    This is a "new to me" trailer. I have no history on it. Smoke and a small amount of fluid coming from reservoir overflow tube.
    Oil level is fine BUT there's another place to add oil. I dont know what that is. There's no dip stick. It looked bone dry. I added about a gallon of oil to it. Refilled the antifreeze which was only half full.
    It's running now. Still smoking out of overflow tube. And it puked a bunch of antifreeze when I started it back up. No codes yet!!
    So what is that other thing I added oil to and how full should it be.
    Any other ideas welcome as to why it's over heating
  2. Jennyspete
    Apr 3, 2010
    71
    Thanks Received:
    47
    ma
    Ok an update. Fan belt is very loose. Could that cause it to over heat. That's probably a dumb question.
  3. 25(2)+2
    Sep 18, 2006
    18,756
    Thanks Received:
    45,795
    the road less travelled
    Fan belt, runs up to the top mounted radiator.
    Could be tensioner.
    Yes. It will cause the problems that you're seeing.
    KB3MMX and Jennyspete Thank this.
  4. reeferwrencher
    reeferwrencher Medium Load Member
    Aug 4, 2018
    597
    Thanks Received:
    1,554
    Sounds like you added oil at the timing cover cap.The dipstick is the cap beside the oil filter.Purging coolant is usually a sign of a bad head gasket.Is the coolant bottle black?
    KB3MMX and magoo68 Thank this.
  5. MM71
    MM71 Heavy Load Member
    Jun 28, 2008
    760
    Thanks Received:
    991
    AZ
    If its blowing out the overflow ... as stated, head gasket.
  6. KB3MMX
    KB3MMX Road Train Member
    Dec 29, 2014
    3,075
    Thanks Received:
    2,596
    Orrstown, PA
