Set/Adjust Clock on 2016 Freightliner
Discussion in 'Experienced Truckers' Advice' started by tscottme, Apr 22, 2016.
  1. tscottme
    tscottme Road Train Member
    Jul 25, 2008
    13,908
    Thanks Received:
    26,230
    Somewhere out West, in my mind.
    Can anyone give me help on setting/adjusting the clock on a 2016 Freighliner daycab?
    I was able to go through the menu on the central LCD display between the Tach & Speedo, but all I found were settings for Daylight Savings and timezone. There aren't any books/manuals in the truck. I am hoping this 2016 daycab dash is similar to OTR trucks and one of you have one of them.
    Thanks
  2. nofreetime
    nofreetime Road Train Member
    Oct 22, 2013
    1,271
    Thanks Received:
    1,310
    This question has been asked before. And from what I remember about that thread, you're going to need a witch, a rabbi, a priest, and a really big hammer. Good luck.
  3. upnorthwpg
    upnorthwpg Road Train Member
    Sep 23, 2011
    1,727
    Thanks Received:
    2,468
    Hold down title/menu button. Use the cat buttons to move to clock. Hit 6(ok) to adjust.
  4. RoadRooster
    RoadRooster Road Train Member
    May 10, 2015
    4,121
    Thanks Received:
    6,709
    Fort Myers, Florida
    for this, you need an 11 year old kid
    RustyChops41 Thanks this.
  5. ChaoSS
    ChaoSS Road Train Member
    Sep 20, 2014
    3,338
    Thanks Received:
    6,755
    That's to change to 24 hour time. Setting the clock requires a voodoo priest trained in the seven dark arts, the blood of seven virgins ( 2 male, 5 female) killed under the light of a blood moon, a silver blade forged in the year 1327 (preferably the first half) and a half empty bag of Purina puppy chow.
    nextgentrucker and tarmadilo Thank this.
  6. snowwy
    snowwy Road Train Member
    Jul 6, 2009
    20,527
    Thanks Received:
    13,263
    Driver. Your only options are timezone and 12/24 hours. Just select the time zone to match your time
  7. tscottme
    Jul 25, 2008
    13,908
    Thanks Received:
    26,230
    Thanks, but I don't have buttons anywhere marked title/menu or cat. On the steering wheel I have +, -. On the dash I have Return, and Back.
  8. tscottme
    Jul 25, 2008
    13,908
    Thanks Received:
    26,230
    Thanks. I was able to set the correct timezone and 12/24. But the clock was still 6 hours behind correct time. It's a replacement truck. Asking other drivers usually generates "It has a clock?"
  9. Bo Hunt
    Bo Hunt Light Load Member
    Aug 6, 2015
    277
    Thanks Received:
    293
    The correct answer is have a mechanic go into the ECM and change it. Some of the dash configurations are factory set, and when a Qualcomm or similar system is installed, the ECM is reset to midnight, starting the time there. So unless they reset your system at midnight, your clock is forever off until you can get into a shop to get it fixed.
    darthanubis Thanks this.
  10. snowwy
    Jul 6, 2009
    20,527
    Thanks Received:
    13,263
    The keywords being SELECT THE TIMEZONE TO MATCH YOUR TIME. not the timezone to match your timezone.
    The clock requires one of them laptops loaded with the diagnostic software. $15,000 i think that software costs.
