Split sleeper
Discussion in 'Experienced Truckers' Advice' started by Night Ranger, May 8, 2014.
  1. Night Ranger
    Night Ranger Bobtail Member
    May 8, 2014
    20
    Thanks Received:
    4
    After driving my 10hrs what is the minimum amount of time I have to stay in sleeper berth before I can drive again and for how many hours before I have to finish my split sleeper berth.how many times can I split sleeper berth in my 70
  2. Mark Kling
    Mark Kling Technology Contributor
    Sep 23, 2007
    10,935
    Thanks Received:
    4,216
    Statesville, NC
    Study this one well. Understand it well. If not it will mess up your log book for several days.
  3. scottied67
    scottied67 Road Train Member
    Mar 14, 2010
    10,818
    Thanks Received:
    12,622
    california norte
    The answer is:
    It all depends.
    Depends on how much time do you have left on the 14 and 70?
    You have to remember you are splitting your 14 clock as well as your 11 clock. If it took you 13.5 hours of your 14 to run 10 hours on the drive line, after 8 hours in the sleeper ,you'd only have .5 hours left to drive.
    I recommend downloading the Eclipse logbook software from Logbook.com and inputting your actual logs into it and it will show a red line which you cannot drive past. I use it when I split sleeper berth just to double check I don't go into violation.
  4. Mev
    Mev Road Train Member
    Jul 29, 2009
    3,109
    Thanks Received:
    1,102
    I just roll out after 8 , drive a few hours , take another 10 then drive some more...I hope this is legal , never do I hear safety complaining that I'm doing something wrong
    scottied67 Thanks this.
  5. otherhalftw
    otherhalftw R.I.P.
    Nov 18, 2008
    13,081
    Thanks Received:
    45,332
    CA...gold discovery foothills
    First of all...you have 14 hours to drive 11 hours. In figuring split sleeper, the amount of drive time available after the 8 hours SLEEPER BERTH, would be the amount of drive time you did not use of your 11 before taking the 8 hour sleep. So in your example, you would have 1 hour available to drive before taking a 2 hour break (sleeper or Off Duty or combination), after the 2 hour break you would have the time you drove before your 8 hour sleeper, available to drive this round. This pattern will continue until you reset your 11/14 hour clock with a 10 hour uninterrupted break.
    The whole point of split sleeper is to extend the 14 hour clock in increments of 8 and 2.
    Subutai, Hammer166, EZ Money and 3 others Thank this.
  6. 70s_driver
    70s_driver Medium Load Member
    May 4, 2014
    611
    Thanks Received:
    358
    Once you climb in the sleeper, 8 hours. Anything less doesn't count. Otherhalf is correct on the other two hours. Usually though, if you have less than 2 hrs left of your 11, its best to just go ahead and do your 10 off, that way, youll have 11 and 14 again as long as it doesn't throw you over your 70. The only way I split is if Im running a very tight schedule.
  7. scottied67
    Mar 14, 2010
    10,818
    Thanks Received:
    12,622
    california norte
    It doesn't give you more hours to drive or represent a shorter break.
    I mostly use it to flip the driving clocks around, say don't want to drive all night, stop and take an 8 hour sleeper then get up and drive about half of the 11 then do a 2 hour break and have again half of the 11 available again.
    otherhalftw Thanks this.
  8. Wooly Rhino
    Wooly Rhino Road Train Member
    Jul 6, 2008
    3,367
    Thanks Received:
    5,648
    Liberty, Missouri
    You are suffering from newbieitis on this question. HOS is a tool for you to use to keep from being overworked. If you have driven 10 hours why do you not what your entire 10 hours off? You can drive for 11 hours so you don't have to spend anytime in the berth and you can drive 1 more hour. If this is a test question. But why would you want to? 8 hours a day of driving is plenty. Never run up against your limits. Relax. Running hard keeps wages down. Run safe, get your fuel bonus. Why should you work yourself to death only to have to wait to be unloaded.
    Subutai Thanks this.
  9. tangerineGT
    tangerineGT Road Train Member
    Aug 26, 2013
    2,277
    Thanks Received:
    1,766
    Red Lion , PA
    Uhhhhh . 8-2 always messes me up , but for some dumb reason I use it anyways . Well only when it makes sense though..
  10. mattbnr
    mattbnr Road Train Member
    Aug 19, 2010
    1,950
    Thanks Received:
    837
    Tama,Iowa
    I figure if I've sat for 8 I might as well sit for 2 more and get a full 14 back. Never understood the point behind the split sleeper provision.
    Moosetek13 Thanks this.
