tech assistance, please.
Discussion in 'Ask An Owner Operator' started by rolls canardly, Mar 27, 2011.
  1. rolls canardly
    rolls canardly Road Train Member
    Feb 7, 2009
    1,611
    Thanks Received:
    3,825
    mt. pocono. pa.
    Where's the waterpump in a Detroit diesel in a Freightliner tractor?
    Who can send me a PDF File of assembly for 3126 CAT motor;
    I have a zero miles short block to build up.
    Reason for edit: Email removed at poster’s request.
  2. canuck in da truck
    canuck in da truck Road Train Member
    Aug 6, 2010
    4,352
    Thanks Received:
    2,601
    western pa
    its the same place as it is on any detroit powered truck--right side about 8 inches from front--lower corner--just follow the lower radiator tube and hose
  3. Mack185
    Mack185 Medium Load Member
    Feb 25, 2008
    448
    Thanks Received:
    262
    Bud you're being way to vague. You need to list your year/model plus what Detroit are you working with?
    I looked on accessfreightliner but without any info I just plugged a vin off a 2006 tractor but without knowing for sure I'm not going to wade through all the BS service guides without knowing what your working on.
    I'd follow the above advice, a water pump is a very simple repair and easy to find.
  4. rolls canardly
    Feb 7, 2009
    1,611
    Thanks Received:
    3,825
    mt. pocono. pa.
    thanks for the help; I have Caterpillar engines, no Detroit experience
    at all.
    My son-in-law is taking the CDL test Monday and Thursday
    and the instructor is saying water pump is drivers side on shaft between air pumpand power steering pump. Looks to me a hard place to have a pump to make it sealed on both sides?? Also looks liike a gear case to power the pump from a geartrain from the camgear. Just wanted to make sure.
