Turning Engine Off
Discussion in 'Western Star Forum' started by CDLman63, Dec 17, 2020.
  1. CDLman63
    CDLman63 Bobtail Member
    45
    15
    Apr 22, 2018
    Hattiesburg, MS
    My instructor in CDL school told me that after running the truck "hard" on the highway, it is not good for the engine to cut it off immediately after stopping somewhere. He said to let the engine idle for a few minutes before cutting it off. How would cutting the engine off immediately after running "hard" on the highway, hurt the engine?
    Thx.
  3. Numb
    Numb Crusty Curmudgeon
    4,333
    10,298
    Jan 30, 2012
    Charlotte, N.Carolina
    hot oil in the turbo needs to cool down, I believe.
    shutting an engine off after a hard run and they water is not circulating and cooling and they actually get hotter for a while.
    CDLman63, Rideandrepair and bzinger Thank this.
  4. rbrtwbstr
    rbrtwbstr Road Train Member
    3,402
    7,948
    Jul 11, 2012
    in the bush somewhere
    Well, Three Mile Island was running hard before it stalled and melted down.
    Ok, might be a bit over dramatic.
    When you're running, working the engine, it creates heat. Your cooling system circulates cool water to cool the engine. When it's hot, and you stop the coolant flow, the engine, (and the oil) that's still hot, will get hotter. Heat is no good for the oil, or the engine.
    With the newer engines that run hotter, it's even more important to let them cool a bit before shutting them down.
  5. Judge
    92,397
    Cools turbo off, used to old rule was 5 minute warm up and 5 minute cool down.
    CDLman63 and Rideandrepair Thank this.
  6. Hulld
    Hulld Road Train Member
    2,884
    6,568
    Oct 19, 2015
    Upstate NY
    Shutting it off with out a proper cool down cokes up the bearings with burnt oil in a hot turbo.
    Usually safe for a shut down when the turbo is 350 degrees or cooler on the pyrometer.
  7. AModelCat
    164,918
    Mainly for allowing some cool down time for coolant, oil and exhaust. If you've got a manual fan, turn it on while idling. Helps pull the heat out better.
    Idling also allows the turbo to slow down. Those suckers spin upwards of 80,000 RPM and are precision balanced. If you just finished working that engine and then shut it off, you'll likely be letting the turbo dry spin for a little bit. Better to let it slow down while still being fed lubrication.
  8. LameMule
    LameMule Road Train Member
    1,148
    7,418
    Jan 19, 2020
    Montana
    Different metals cool and heat or expand and contract at different rates. Also important for the turbo.
  9. pavrom
    pavrom Road Train Member
    3,217
    7,421
    Apr 29, 2012
    NE illinois
    If he mentioned this he must be good ! Listen to him :)
  10. bzinger
    bzinger Road Train Member
    16,657
    66,202
    Dec 10, 2014
    omaha , ne
    893k on my isx turbo (2012) always cooled down .
  11. Doealex
    Doealex Medium Load Member
    597
    1,132
    Feb 21, 2018
    Agree with all the above and also heard that turbos don’t have bearings. It gets lubricatated by oil only (RPMs are too high for any bearing). As it spins fast when you shut your engine off quickly that turbine is still spinning too fast before it stops coking oil that left there leading to premature turbo damage.
