Volvo VNL ISX troubles with starter or other electrical issue?
Discussion in 'Volvo Forum' started by ThreeM, Mar 30, 2014.
  1. ThreeM
    ThreeM Light Load Member
    Mar 30, 2014
    56
    Thanks Received:
    Hi guys,
    I have 1998 VNL Cummins M11 and recently started experiencing problems starting the truck.
    Sometimes it fires up right away and other times just clicks and can't start.
    If i turn the key on and bridge the big posts on the relay on the firewall all I hear is clicking noises from the starter, almost melted the cables but could not fire it up. Went under the truck and knocked the starter with rubber mallet, connected the posts again and finally fired up the truck.
    I replaced the starter 3 months or so ago.
    Is it possible my almost new starter is bad (starter is refurbished Delco but this is the only one my VOLVO dealer sells).
    Or I have some other electrical issues I can't figure out.
    It really drives me crazy at this point and I will appreciate any help.
    Sincerely,
  2. RSQ20
    RSQ20 Medium Load Member
    Jul 11, 2013
    315
    Thanks Received:
    93
    Upper Fraser Valley, BC Canada
    Use an amp clamp and measure the draw, seems you may have a hanging armature....
    ... Philip
    ThreeM Thanks this.
  3. CondoCruiser
    CondoCruiser The Legend
    Apr 18, 2010
    19,726
    Thanks Received:
    18,734
    Tennessee
    Double check your main battery hot at the starter. Any bit of corrosion under the lug or even an 1/8th turn too loose and it will do that. Have someone turn the key at night time and you'll see sparks in the dark at the bad connection.
    ThreeM Thanks this.
  4. ThreeM
    Mar 30, 2014
    56
    Thanks Received:
    I will measure it and will post the results.
    I was thinking if it's the starter just replace it since it's still under warranty. The problem is they will give me another re manufactured Delco and I may end up with the same issue...
  5. ThreeM
    Mar 30, 2014
    56
    Thanks Received:
    Already looked at that and no corrosion and it's not loose, I will check again tonight to see if there are any sparks.
  6. wonderdog24
    wonderdog24 Medium Load Member
    Mar 1, 2012
    377
    Thanks Received:
    127
    Puyallup,Wa
    It will be the ground from the starter to the frame.... Clean that up n you will be good to go....
    ThreeM Thanks this.
  7. baha
    baha Road Train Member
    Jul 25, 2013
    4,137
    Thanks Received:
    2,837
    ga
    Buy the new type replacement starter 220$ new gear/redu. so it will sound like a old dodge starting up, most of sol. they use now on recon. starters are not good
    ThreeM Thanks this.
  8. ThreeM
    Mar 30, 2014
    56
    Thanks Received:
    I was thinking about buying a new starter but I'm not sure what brand should I get. My dealer sells only reman. and does not carry any other brands except Delco :( They try to push their items only. Any suggestions?
  9. RSQ20
    Jul 11, 2013
    315
    Thanks Received:
    93
    I fail to understand why you are not testing the issue, guessing cost time & money...
    ..... Philip
  10. ThreeM
    Mar 30, 2014
    56
    Thanks Received:
    testing will be the first thing I will do as soon as I return home, I regret not buying amp clamp for the truck since they were $30 at Sears.
    Sincerely,
    ThreeM
