What speed to downshift 10 speed transmission?
Discussion in 'Questions From New Drivers' started by Shaner.STL, Jan 23, 2019.
  1. Tombstone69
    Tombstone69 Road Train Member
    Dec 20, 2018
    1,010
    Thanks Received:
    1,346
    Jersey shore
    Good luck,you'll get it,everybody does,after doing it a couple thousand times it will be second nature.Just think when you're on your own you'll be able to practice all you want.Here's a tip for when you're in traffic,leave a lot of stopping distance in front of you,that way you don't have to keep shifting.Just stay in 1 gear and creep along,just watch out for 4 wheelers,they see a hole and right away they have to jump in it.Silly drivers.
  2. Pumpkin Oval Head
    Pumpkin Oval Head Road Train Member
    Jun 24, 2010
    1,679
    Thanks Received:
    1,155
    Scranton PA
    You can downshift faster by skipping gears.....after you get into 8th gear, hit the brakes until you slow down to 15 mph and then grab 6th gear. Hit the brakes hard, so your instructor has his seat belt lock up.....then he will have something to yell at you about!! Just kidding, use moderate brake pressure.
    Ask your instructor if he wants you to skip gears when downshifting....it would be good practice. In the real world there will be times you have to skip some gears. If a car pulls out in front of you, you may need to brake hard, and skip several gears.
    By the way, when you do the cdl driving test, the examiner will likely ask you to only downshift a few gears. The examiner will not ask you to do what your instructor is telling you to do.
  3. Shaner.STL
    Shaner.STL Light Load Member
    Jul 26, 2017
    63
    Thanks Received:
    26
    Thanks guys. Its going better thus far today. Shifting the same for 9th and 8th, but 7th and 6th I’m shifting at a higher speed. Realized I wasn’t kicking the rpms up high enough before so all the advice has helped! He’s still finding things to get on me ab but nothing like before. Yeah, he would not take kindly to me slamming the brakes haha!
  4. jammer910Z
    jammer910Z Road Train Member
    May 28, 2015
    2,446
    Thanks Received:
    6,522
    Tell your Instructor..
    "I'm screwing this cat! You hold the tail out of the way!"
  5. BrandonCDLdriver
    BrandonCDLdriver Road Train Member
    Sep 1, 2017
    1,191
    Thanks Received:
    1,462
    Trucks are definitely like women.
    Most of them are dirty, old and overweight.
  6. Winnyf1
    Winnyf1 Road Train Member
    Jan 14, 2015
    4,449
    Thanks Received:
    9,645
    Evansville, IN
    Duct tape for your instructors mouth? You got it about right on the speeds.
  7. Cam Roberts
    Cam Roberts Road Train Member
    May 13, 2018
    1,621
    Thanks Received:
    1,938
    why You downshift so much?. You Jake brakes don’t work?
  8. Shaner.STL
    Jul 26, 2017
    63
    Thanks Received:
    26
  9. Pumpkin Oval Head
    Jun 24, 2010
    1,679
    Thanks Received:
    1,155
    Scranton PA
    One of the tractors I drove did not have a jake brake.....was always loaded at 80k.
    Cam Roberts Thanks this.
  10. whosfate
    whosfate Light Load Member
    Jan 17, 2018
    103
    Thanks Received:
    176
    State College, PA
    After you get away from your instructor, find a company that runs 13 or 18 speeds. Much nicer to be able to split gears and shift with your thumb :cool:
    Pumpkin Oval Head and Cam Roberts Thank this.
