When and how much to slide axles??
Discussion in 'Questions From New Drivers' started by NatureGirl22, Oct 5, 2014.
  1. NatureGirl22
    NatureGirl22 Light Load Member
    Aug 15, 2014
    146
    Thanks Received:
    128
    Okay, here I am again. I have a really important question. If you're reading this, please answer as soon as possible.
    Here it is. When adjusting and sliding tandems, how do you know which hole to put it in? If the load is heavy or the axle is heavy, how do you adjust the tandems without moving the fifth wheel? (The fifth wheels don't move, in this case.) Do you slide forward or backward? How do you determine which hole to put the tandems into? If it is too light, which way do you slide it? Basically, could use a good crash course in sliding tandems here. We don't know how to determine where and how much to slide tandems (which hole to put them into). I know I sound like the newbie I am here...please excuse it...
  2. ramblingman
    ramblingman Road Train Member
    Jan 12, 2014
    1,152
    Thanks Received:
    1,115
    I've never had sliding tandems as I'm a flatbedder. Iirc though the rule of thumb is 500 lbs is shifted per hole moved in either direction. Moving forward takes weight off drives and puts it on trailer. Moving backwards does the opposite.
  3. Trckdrvr
    Trckdrvr Heavy Load Member
    Dec 25, 2010
    742
    Thanks Received:
    621
    Georgia
    ok..i wont go into length
    have you scaled out load?
    tow614 Thanks this.
  4. tow614
    tow614 Road Train Member
    Mar 18, 2013
    3,759
    Thanks Received:
    4,631
    Please give your axle weights and we can advise you
    Lepton1 Thanks this.
  5. 70s_driver
    70s_driver Medium Load Member
    May 4, 2014
    611
    Thanks Received:
    358
    when sliding your trailer tandems, figure about 200-250 lbs per hole.if you weighed your truck and your trailer wheels are weighing heavy at 35,000 lbs, you would need to move your tandems back about 4 holes and then reweigh it. if your tractor tandems are weighing 35,000, slide your trailer tandems forward 4 holes and reweigh. sliding your trailer tandems forward takes weight off the tractor and puts it on the trailer. sliding your trailer tandems back puts weight on your tractor tandems and takes it off the trailer.
  6. hthammond
    hthammond Bobtail Member
    Apr 22, 2014
    28
    Thanks Received:
    5
    Sultan, Wa
    Good Job .............................
    70s_driver and BrenYoda883 Thank this.
  7. STexan
    STexan Road Train Member
    Oct 3, 2011
    14,963
    Thanks Received:
    29,154
    Longview, TX
    This is about as basic as I can illustrate the issue in "simple terms" and assumes the cargo volume/weight is all loaded evenly. Now for an exercise, looking at the trailer illustrated, imagine if the rear 33% of the cargo volume, comprised 50% of the cargo weight ... this would amplify the weight effects of any changes to the pivot point. Point is, if rear 1/3 is "heavy", each hole will move x weight off/onto the nose. If rear 1/3 is "light", each hole will move y weight off/onto the nose. So there is no hard and fast rules as to how much each hole will change weight configuration. Each load is different in most cases in terms of weight distribution. But the physics are the same. It's about the weight that is "behind the pivot point" that effects the weight at the nose. For the purposes of this exercise, don't concern yourself with steer weight, only concern yourself with how much weight is at the trailer front, based on the trailer tandems position.
    You're essentially dealing with a fulcrum.
  8. RoadCall
    RoadCall Road Train Member
    Mar 12, 2012
    1,490
    Thanks Received:
    936
    Actually the weight per hole varies depending on how far apart the wholes are. Some are about 200lbs while others are further apart and would be closer to 400lbs or so.
  9. freightwipper
    freightwipper Road Train Member
    Mar 24, 2014
    9,366
    Thanks Received:
    11,439
    OTR
    I hope you are asking these questions in trucking school and not out on your own yet.
    If you are... poo poo on you and the company you're with.
    I learned this my first week in CDL school.
    The way I remembered it is well ... truck driving everything is opposite world. Just like in backing.
    Sooo if I have too much weight on my tandems.. I bring the tandems back to more the weight up.
    If there's too much weight on my drives I more my tandems up to being more weight back.
    As far as how much... well it helps to pay attention to how the trailer was loaded before you close the doors.
    How many hole.. usually I guesstimate 1 hole for every 300-400 pounds
    Usually I'm at 78-79 k to begin with anyway if I gotta deal with sliding.
    less freight weight would be less per hole also.
    fun fun
  10. Bry
    Bry Light Load Member
    Apr 16, 2013
    157
    Thanks Received:
    86
    Always slide toward the overweight spot. Yeah, usually 250-350 lbs per hole. Scale and rescale till you get it right.
    putter and freightwipper Thank this.
