Why is 700 Watt microwave shutting down 2,000 Watt inverter?
Discussion in 'Experienced Truckers' Advice' started by JC1971, Mar 2, 2025.
  1. JC1971
    JC1971 Road Train Member
    Jul 29, 2013
    2,660
    Thanks Received:
    9,692
    L.A.
    Not right away but after a few minutes I hear a beeping from the truck like it's a low-voltage indicator. I actually have the truck running and it still does this. Eventually the inverter cuts off and resets. The truck is an Intertrashional if that makes a difference.
    blairandgretchen Thanks this.
  2. Antinomian
    Antinomian Road Train Member
    Feb 17, 2013
    2,108
    Thanks Received:
    3,326
    The inverter is shutting down because of low battery voltage, the same reason the truck low voltage alarm is going off. I'd test the batteries first, but you may also have a failing alternator.
    And keep in mind the microwave puts out 700 watts, but it uses more than that.
    tscottme, JC1971 and AModelCat Thank this.
  3. Ridgeline
    22,379
    Thanks Received:
    116,154
    What make and model of inverter, how is it hooked up and what size cables?
    these questions all matter on what the real problem is.
  4. ElmerFudpucker
    May 17, 2024
    4,820
    Thanks Received:
    52,404
    Have you checked your battery connections?
  5. drivingmissdaisy
    drivingmissdaisy Road Train Member
    Jun 10, 2019
    1,947
    Thanks Received:
    3,311
    One of two problems, either a worn out inverter or worn out batteries. Could be a bad connection to the batteries.
    I don't think Internationals beep from low voltage. I drove one for years. I think that's the inverter beeping to warn you it's about to have to shut off. If the display isn't showing low voltage then its not the truck beeping.
  6. 86scotty
    86scotty Road Train Member
    Aug 27, 2017
    4,462
    Thanks Received:
    11,947
    Appalachia
    How long are you running your microwave? None of them, even with an inverter, do well if you're running the microwave for more than 2-3 minutes. Are you cooking frozen dinners or something?
  7. Ex-Trucker Alex
    Ex-Trucker Alex Road Train Member
    Jan 7, 2023
    1,396
    Thanks Received:
    2,371
    I'm assuming you are running the motor whenever using high-draw appliances like this?
  8. drivingmissdaisy
    Jun 10, 2019
    1,947
    Thanks Received:
    3,311
    Did you read the OP?
    JC1971, 86scotty and blairandgretchen Thank this.
  9. blairandgretchen
    Dec 9, 2011
    13,376
    Thanks Received:
    71,897
    South west Missouri
    He never does.
    86scotty, Espressolane and Razororange Thank this.
  10. Espressolane
    17,500
    Thanks Received:
    107,073
    Is this a new thing, or has this been going on from the start of use?
    A 700 watt inverter can draw up to 3 times the operating watts on startup.
    After start up, it will likely draw 850 to 900 watts operating rate.
    If new, would look into all wire connections, clean any corrosion, make sure all connections are good and tight.
    Inspect and test all your batteries. Make sure they are in good condition, this should include a static load test, and recovery time. Possibly you have weak batteries and can’t buffer the load demand. Finally test the charging system. If you can’t remember or don’t know when the drive belts have been replaced, probably a good idea to have that done.
