‘15 Volvo VNL 630 D13 headlight/turn signal issues
Discussion in 'Volvo Forum' started by Trucker2211, May 26, 2018.
  1. Trucker2211
    Trucker2211 Light Load Member
    94
    91
    Mar 3, 2015
    I hit a deer a while back that demolished the front right side of my truck and recently got it fixed at a local body shop. The repairs look great and everything but I see now that they used an aftermarket headlight assembly to replace the busted one on the passenger/right side. The left side is still factory OEM. All of a sudden I start getting the “Check” light on dash and message that says “right front turn indicator malfunction” Ok, so obviously I replace the bulb, nothing. Trace the wires and disconnect & reconnect everything, nothing. Shut the truck off and let it cycle thru a couple times and bam, the message is gone! Ok cool, well about 200 miles down the road it happens again. Shut truck off and cycle ignition and of course it goes away. Another 200-300 miles down the road and it just happened again. What in the world is going on here? Anybody ever ran into this issue? Any help or suggestions would be greatly appreciated!! Thanks.
  3. Jacoooooooo
    Jacoooooooo Heavy Load Member
    748
    1,054
    Oct 20, 2013
    I’d bet the chineese headlight is already trash.
  4. Sharky88
    Sharky88 Heavy Load Member
    715
    851
    Sep 25, 2013
    The lights are controlled by a computer. If it is not the original Oem light the resistance may be different. It will show a fault because of that. The LCM needs to be reprogrammed.
    Trucker2211 Thanks this.
  5. Jacoooooooo
    748
    1,054
    Oct 20, 2013
    Reprogrammed for what? If he has the same type of light there should be no need for reprogrammimg. If he put LED’s, that’s different, but not normal replacement halogen headlight.
    He just have poor quality chineese lamp, that’s it.
  6. Trucker2211
    94
    91
    Mar 3, 2015
    Yeah they are not anything special like the LED or HID, just the regular stock halogen lights that uses the factory bulb #’s so it definitely shouldn’t need reprogrammed. So is this issue the symptoms of a cheaply made light?
  7. Snailexpress
    2,675
    6,068
    Apr 28, 2014
    Rocky
    Cheaply made bulb socket and or bulb. Make sure bulb is installed properly as it looks like you have intermittent connection somewhere.
  8. Jacoooooooo
    748
    1,054
    Oct 20, 2013
    That’s my bet. Usually wiring plugs on aftermarket headlights give most problems. They just don’t plug in tight enough and electrical connection is bad.
    Or something inside the lamp. Try to see if your repair shop will take it for warranty claim.
    Burnt bulb would give you a „turn signal open circut message”, not malfunction.
  9. Trucker2211
    94
    91
    Mar 3, 2015
    Ok thanks for the info. I remember the bulb looking cheap and not having a brand name on it anywhere and yeah the pigtail where the bulb clicks into place is definitely mass-produced in a Chinese factory lol it just doesn’t have that solid feel like the OEM does. Also forgot to mention; the code I’m getting has an FMI:6 which is circut short to ground or input volts above 16v. FMI 5 is open circuit which usually means bad bulb from my experience
