'02 9400i cabin heat
Discussion in 'International Forum' started by silver dollar, Oct 25, 2012.
  1. silver dollar
    silver dollar Medium Load Member
    481
    211
    Jan 31, 2009
    Central North Carolina
    Greetings fellas. I need some help. The heat for the cab of my truck is not what it should be. I don't think the temp control is working. There in no change when it is moved from cool to hot. The sleeper control works perfect. Where should I start to look, and what should I be looking for? Thanks
  3. Heavyd
    Heavyd Road Train Member
    7,838
    6,293
    Feb 4, 2009
    Could be a few things. The cab blend door and actuator are located in the heater box under the passenger seat. You will have to remove the seat and box cover. There will be two actuators in there, one for the bunk, and one for the cab. The cab actuator is most forward one. With the heater box opened up, move your heater control full cold and hot and see if the actuator is moving at all. If it doesn't move at all you could take off the bunk actuator and just plug it in to the cab actuator connector and test again to determine if the cab actuator is bad or not. If it still doesn't move you can try a heater control module. The cab blend door and housing do tend to warp over time since they are just plastic so the door could be just jammed too. All components are easy to change. Just be careful, since most of those parts are plastic they get very brittle over time due to the heat and will break easy.
    Tug Toy and silver dollar Thank this.
  4. Taildragon
    Taildragon Heavy Load Member
    723
    450
    Jun 22, 2012
    Indiana
    Along with what Heavyd said, you might also make sure that the water valves on the engine heater hoses are all open, sometimes when a person opens them in the cooler weather, they forget that sometimes the cab heater hoses have valves as well as the bunk heater hoses have valves, four valves total should be open if the system is plumbed this way.
    silver dollar Thanks this.
  5. silver dollar
    481
    211
    Jan 31, 2009
    Thanks. Is the heater control module under the seat also?
  6. silver dollar
    481
    211
    Jan 31, 2009
    Thanks. Mine just have two valves. But some days it blows warm, and other days it cool. But never hot. I would kinda like my feet warm instead of the back of my head.:biggrin_2559:
  7. Heavyd
    7,838
    6,293
    Feb 4, 2009
    The control module is just the part with the heater controls in the main dash panel.
  8. silver dollar
    481
    211
    Jan 31, 2009
    Thanks. I notice the knob spins very easily I can just barely feel the "clicks" when it is turned. I'm thinking there should be more of a drag, if you will, or the clicks should feel more pronounced. What say you?
  9. Heavyd
    7,838
    6,293
    Feb 4, 2009
    Yep, I think your right. It should have detentes. If it feels too free it is probably bad.
  10. Rfarmer
    Rfarmer Bobtail Member
