02 9400i With C15 6NZ running issues
Discussion in 'Trucks [ Eighteen Wheelers ]' started by silver dollar, Oct 29, 2014.
  1. silver dollar
    silver dollar Medium Load Member
    481
    211
    Jan 31, 2009
    Central North Carolina
    My 6NZ cat in 02 9400 has developed some running issues. At about 1300 RPM it starts to "cutout". It does this loaded and empty I can just feel it more when empty. It happens between 1300 and 1500 RPM. In lower gears, say 4th, at 1300 going across a parking lot for instance, it felt as bucking. Above 1500 it runs fine. Has any else experienced symptoms such as this that can maybe give me some idea what could be causing this. Thanks in advance
    Chinatown Thanks this.
  3. Chinatown
    Chinatown Road Train Member
    77,815
    184,851
    Aug 28, 2011
    Henderson, NV & Orient
  4. maggard359
    maggard359 Medium Load Member
    476
    413
    Nov 20, 2013
    Florida
    See if you can find a throttle sensor and swap. You will need to calibrate also. Sounds to me like a dead spot in the pedal. Find somebody to let you borrow theirs before buying one, it's a simple swap. Calibrate turn key on, press pedal fully to floor three times and then key off again.
    silver dollar Thanks this.
  5. Superhauler
    Superhauler TEACHER OF MEN
    12,209
    100,735
    Jan 30, 2010
    keep stroking.
    where to begin? check fuel pressure, filters, plug in et to see what is going on, could be a cam or crank sensor, or a wire harness issue. or an injector acting up. again plug into the laptop to see before throwing $$$ and parts at it.
  6. Scrapper
    Scrapper Light Load Member
    289
    83
    Jan 19, 2010
    Nashville, AR
    quick check....get out on the highway and put into cruise...run up and down past the rpm range that is giving your problems. If it does not do it, but does on on foot throttle...it is the throttle position sensor. The cruise is run by the ECM and does not use input through the TPS. Its an 02 and if has never had one its probably time. They'll only progressively get worse. Its an easy fix. As already said test before buying parts. This will tell you real quick if its the TPS...have replaced 4 or 5 this past year on 99-03's. Seems like about the right area for yours.
  7. Thed302
    Thed302 Light Load Member
    114
    70
    Oct 30, 2014
    USA
    Try this ^
  8. silver dollar
    481
    211
    Jan 31, 2009
    Hi guys. Sorry I hadn't posted anything, but I was running hard and taking my 10 in the bunk, no time for the computer.
    I tried this today. On cruise, it seems to do OK, but on the pedal it runs erratic. And it is getting worse. Now, where is the TPS? At the pedal or on the engine. I really appreciate the help.
  9. maggard359
    476
    413
    Nov 20, 2013
    Florida
    It's on side of pedal. Has a three wire plug, easy to change just be sure and do the recalibration on new one.
  10. silver dollar
    481
    211
    Jan 31, 2009
    Thanks for the reply. Is the sensor a Cat part, or an International part, or just general aftermarket? Thanks.
  11. maggard359
    476
    413
    Nov 20, 2013
    Florida
    It's usually a caterpillar part, could be Williams, but should find it anywhere.
