02 Peterbilt 379 won't start.
Discussion in 'Trucks [ Eighteen Wheelers ]' started by n1xrf, Apr 16, 2016.
  1. n1xrf
    n1xrf Light Load Member
    166
    32
    Jul 18, 2011
    somewhere in the USA
    02 Peterbilt 378, with a 6nz cat. Ran great, pulled into the yard, driver said it had a bad battery. Had the parts changer change battery, now the truck won't start. Has plenty of fuel, primer is hard, filter is full. Have 12v power on ecm pin 70, with key on. Has constant 12v on 3 exam pins with key off. Still won't run. Any ideas?
  3. baha
    baha Road Train Member
    4,137
    2,837
    Jul 25, 2013
    ga
    CK. to be sure ecm is still getting 12v, will it start for a short time on ether? the sensor L side ft.above air comp. will make E model not start and not throw a code,
  4. TAfool
    TAfool Medium Load Member
    631
    850
    Dec 8, 2012
    Cranks, won't start?
    or
    Won't crank?
    Check obvious first. Did all ground and power leads get reconnected?
    TA
  5. n1xrf
    166
    32
    Jul 18, 2011
    Cranks, but no start. All wires are hooked up properly. Will hit on ether.
  6. n1xrf
    166
    32
    Jul 18, 2011
    I forgot to mention, it also won't talk to my nexus iq scan tool. Can talk to abs and trailer abs modules.
  7. Old school 362
    Old school 362 Medium Load Member
    392
    249
    Mar 6, 2016
    Pensacola Fl
    Check elm ground wire. Located next to battery box. Should be a white wire. My .o2
    n1xrf Thanks this.
  8. wore out
    wore out Numbered Classic
    16,719
    204,514
    Jun 5, 2013
    CHASIN THE DEVIL'S HERD
    If it will not communicate with the nexius tgere is a power or ground wire off or in the wrong place on the battery cables. Hopefully a positive on a ground and not the other way around
    n1xrf Thanks this.
  9. Old school 362
    392
    249
    Mar 6, 2016
    Pensacola Fl
  10. n1xrf
    166
    32
    Jul 18, 2011
  11. Old school 362
    392
    249
    Mar 6, 2016
    Pensacola Fl
    Hace u checked fuel pump for pressure.
