03 steering rattle
Discussion in 'Peterbilt Forum' started by maritzio, Feb 4, 2011.
  1. maritzio
    maritzio Bobtail Member
    When I hit a bump the steering wheel rattles I can't seem to find what is wrong just did the bushing front and back but its still there its driving me crazy
  3. Rig Wrench
    Rig Wrench Medium Load Member
    398
    66
    Dec 24, 2010
    northeast
    How many miles are on the truck? what kind of shape is the steering shaft in? the steering joints? i just went throught this on an 05, wound up beeing the steering box. examin all avenues first, box is about a 600 dollar guess:biggrin_25512:
  4. Markvfl
    Markvfl Road Train Member
    1,103
    338
    Nov 29, 2007
    Apopka, FL
    I have an annoying rattle in my steering column that seems to come and go. My truck is an 05 379. It seems to be worse right after a grease job. I've taken the covers off where it sounds like it's coming from but can't find anything that seems loose or worn. I hope it's not the steering box. Is this what you had?
  5. dave_0755
    dave_0755 Light Load Member
    207
    61
    Oct 24, 2010
    Jonesboro,AR
    I have an 04 KW. My steering does the same. It's my steer gear or some call it the steer box. It's the part at the end of your steering shaft. It's mounted on the frame rail, under the hood and in front of your drivers side steer wheel. They are not very hard to change but weigh around 85 pounds and cost somewhere between $600 and $800.
    I need to change mine out too.
  6. Rig Wrench
    398
    66
    Dec 24, 2010
    northeast
    yeah, check everything else first though, that was the first and only time that that fixed the problem. a rattle, or shake could be caused by anything from a bum tire to kingpins to a worn steering shaft, etc.etc.etc.
    Its very possible it could be your box but i woulnt want to tell someone to buy a 600 dollar box and still have a problem:biggrin_25513:
  7. mbt
    mbt Bobtail Member
    8
    Check the "u-joints" in the steering shaft. If I'm not mistaken there are 4 joints in a Pete, 2 under the hood and 2 inside the cab section of the shaft. I had the same problem and changed the outside 2 and that helped but it wound up being one of the inside 2. I just went ahead and changed all 4.
  8. dave_0755
    207
    61
    Oct 24, 2010
    Jonesboro,AR
    I just changed my steer gear out this weekend. It drives like a new truck. Still there was a lot of rattling in the steering wheel. I got home from the shop and noticed it was low on fluid. I guess the shop filled the reservoir but it didn't cycle through the pump. I added more fluid but I haven't drove it yet. I hope this fixed my problem. I will find out this week when I leave out.
    I got my steer gear at truck pro. It was $511 with exchange. I got it put on for next to nothing at a local shop. After I saw how easy it was to put on I saw I could have did it myself. I'm not too worried about that though. The local shop I use doesn't charge very much at all.
  9. dave_0755
    207
    61
    Oct 24, 2010
    Jonesboro,AR
    Steering still rattling at idle. It stops when I bump up the rpms. I'm thinking its the pump. I'm not changing it though. I've put enough on the old KW for now. I'll just deal with a little rattle
  10. paul 1052
    paul 1052 Heavy Load Member
    899
    346
    Oct 9, 2010
    Sand Springs, Ok.
    My '02 379 developed a rattle near the steering wheel this winter only took me 2 months to figure out it's in the turn signal lever assembly.
  11. Diesel Dave
    9,754
    33,547
    Jan 20, 2010
    Hesperia, Ca.
    I was told that there is a sealed pressed bearing on the steering column, and they do wear out.
