04 freightliner Columbia speedometer
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by sergk1989, Dec 16, 2021.
  1. sergk1989
    sergk1989 Bobtail Member
    39
    10
    Jan 23, 2013
    When I start my truck, the gauges do a self test , but the speedometer never goes to zero, so my speed is off by 10-15 pretty much every time. Sometimes it does but lately always off. How can I fix this? I use to tap on the speedometer and occasionally it would go to zero.
  3. Hulld
    Hulld Road Train Member
    2,884
    6,567
    Oct 19, 2015
    Upstate NY
    Short answer is the speedometer is getting wonky on you and should be replaced.
    With that be said sometimes if you cycle the key eight or ten times with 10 to 20 seconds in between key cycles it will zero out.
    If you get it to zero again make sure the gauges go through there full sweep and reset each time before you fire the truck up or it will get out of phase on you again.
    BoxCarKidd Thanks this.
