04 Pete 385
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Bulldog83, Apr 13, 2024.
  1. Bulldog83
    Bulldog83 Bobtail Member
    04 pete 385 cat c13. Unit has no power going to mechanical oil or coolant temperature gauge.have checked all fuses and relay switches. Cannot find a wiring diagram for the life of me on the internet anywhere, thanks in advance for any help
  3. Deere hunter
    2,121
    10,024
    Aug 5, 2017
    Shallowater Texas
    If it's mechanical, the only power going to it will be for the light.
    lester and AModelCat Thank this.
  4. Bulldog83
    Thanks for the reply
    The power is the 12 volt reference. Bad fuse holder in the fuse box. Any thoughts why the same truck will lock up rear brakes with anti lock brake ststem
  5. AModelCat
    164,924
    I'm assuming you mean it locks up the rear drive axle but not the front drive? If so it probably only has speed sensors on the front drive axle and a single modulator valve to control each side.
    Deere hunter Thanks this.
