04 Peterbilt 379 no headlights
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by deanshaski, Aug 31, 2020.
  1. deanshaski
    deanshaski Bobtail Member
    On the headlight switch it still turns the clearance lights on but not the headlights. Checked relays in the fuse box and the one in the dash. When switch is on it looses all power to the wire that had power when switch is off. No idea what to do
  3. bad-luck
    bad-luck Road Train Member
    3,439
    6,332
    Nov 16, 2013
    Baltimore, Maryland
    I had a similar issue. Take out the relay in the fuse box. Then look at the fuse box it self. See if it is black and melted where the relay plugs in. 379's have an issue where the relays vibrate and cause heat and melt the fuse box where the relays plugs in.
  4. Just passing by
    Just passing by Road Train Member
    1,176
    3,140
    Feb 25, 2017
    I think this was a recall and Peterbilt has to replace the harnesses for both headlights.
  5. BoxCarKidd
    BoxCarKidd Road Train Member
    4,551
    6,641
    Aug 26, 2014
    Where exactly is this wire that losses power?
  6. FLHT
    FLHT Road Train Member
    1,429
    2,546
    Aug 2, 2014
    Ground the green wire in headlight bucket.
    The plugs under the Radiator may have corroded.
  7. Hawaiian Punch
    Hawaiian Punch Bobtail Member
    Can anyone tell me if this headlight positions is legal?[​IMG]
    I don't see why not
    As long as you ajust them to the right flare, i don't see any problem.
    What y'all think?
