The neutral light is not coming on and can't get in to the tranny for the on board diagnosis won't start is this cause of this and if so what could it be please and thanks
04 volvo d12 10 speed auto issue
Discussion in 'Volvo Forum' started by hendoh28, Jan 19, 2014.
I had this same issue on the side of the road!!! Its been about 2 years and I've since gotten rid of truck but I remember i had to have it towed to volvo somerset KY cost me about $1500 ..
I actually broke down for some type of fuel issue and when I ran over the little grates on the side of the road it vibrated something loose and it then wouldn't come out of gear, so I had to shut it off, and couldn't get it out of gear and into neutral .
The best thing to do is convert it back into a manual 10 speed. The autotragic transmissions are junk.
I tell you how to start but it takes two people some one has hold the clutch so when the engine starts it wont take off on you , some will have hold it down then have do out to the fire wall and jump across the starter relay , it by the steering shaft , has to big red wire going to it and two small black wires , just jump across the two red ones with a screw driver , a wire will get hot so be careful!!!!!!!!!!!
Finally had it towed and it was the voltage doubler on top of the trans not gonna lie it is a costly black box
sounds like worn X-Y motors..... easy way out - to make convertional plate and fit manual tower... and of course reprogram ECMs
