06 D12 hard start
Discussion in 'Volvo Forum' started by dorlia2, Dec 8, 2021.
  1. dorlia2
    dorlia2 Light Load Member
    149
    28
    Apr 20, 2012
    DOWNERS GROVE
    I am dealing with a problem with prolonged start on a 06 D12 engine since it became colder in the midwest.
    Already checked for fuel leaks and replaced the water separator filter, main fuel filter, fuel return valve, installed new priming pump assembly. I don't see any bubbles in the fuel tanks while engine is running nor any bubbles in the water separator sight glass. Also there is no coolant leak or overpressure in the surge tank. Priming the fuel pump does not help, after a couple pumps the plunger becomes stiff.
    Any ideas would be greatly appreciated
    Batteries and starter are good. After sitting overnight the engine struggles to start as if there is not enogh fuel in the head, sputtering and blowing white smoke for a second when starting.
    No codes on the dash or ToolTech
  3. ibcalm19
    ibcalm19 Road Train Member
    1,463
    2,435
    Nov 30, 2015
    Pennsylvania
    Try this don't know if it will verify the problem ( I believe it's air in the line or losing its prime) Have your tanks filled to capacity when you shut it down & see if you still have a hard start when you fire it back up.
  4. dorlia2
    149
    28
    Apr 20, 2012
    DOWNERS GROVE
  5. ibcalm19
    1,463
    2,435
    Nov 30, 2015
    Pennsylvania
    I don't know for sure just a suggestion. More diagnosis has to be done to pin it down.
  6. dorlia2
    149
    28
    Apr 20, 2012
    DOWNERS GROVE
    Any diagnostics I can do to pinpoint the problem
  7. dorlia2
    149
    28
    Apr 20, 2012
    DOWNERS GROVE
    Anybody in Chicago area that can take a look at this?
  8. dorlia2
    149
    28
    Apr 20, 2012
    DOWNERS GROVE
    Anyone in Chicago area that can take a look at this?
  9. dorlia2
    149
    28
    Apr 20, 2012
    DOWNERS GROVE
    repost
    Reason for edit: repost
  10. flood
    flood Road Train Member
    4,167
    4,045
    Dec 25, 2010
    Sound like a bad injector cup
    dorlia2 Thanks this.
  11. Rob100100
    Rob100100 Light Load Member
    206
    122
    Mar 5, 2016
    Your best bet for Chicago land is
    nasriza
    loudtom and dorlia2 Thank this.
  12. BIGWEM
    BIGWEM Bobtail Member
    8
    I have a similar problem and I have changed almost all fuel parts and my truck still refuses to start
