06 Volvo Cummins ISX LCM Problem
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by djtmy, Jul 6, 2019.
  1. djtmy
    djtmy Bobtail Member
    24
    Jan 28, 2015
    Hello to everyone and thanks in advance for any help...
    Long story short... i just purchased this truck with this problem.
    The issue... after starting truck, 2 messages popping out - Check ECU at the next stop, Check LCM at the next stop... when i’m turning lights on, they working only on first position (parking lights with markers etc), on second position all light disappear outside and inside on dashboard, dimer is not working, no turn signals at any time, no hazard light.
    I can read codes in LCM diagnostics ONLY with parking lights on. If all lights are off or switch is on headlights position i got message “Operation Failed” after 15 seconds of waiting.
    The active codes:
    MID 216 PSID 40 FMI 4 Power Supply, Ignition Key in driving position
    MID 216. PSID 8 FMI 5 Reverse Lamp Low Current or open circuit.
    So far I changed and checked:
    -New light switch
    -New ignition switch
    -New battery’s
    -All Fuses are good
    -All relays looks good and they are clicking when turning lights on.
    -I disconnect battery’s for hours to reset LCM , didn’t help
    -I connected jump cables from battery to ground on firewall... still the same.
    I have 2007 Volvo with D12 engine, so can i swap LCM just to check if that will help or it have to be reprogrammed??
    I working on this problem for last 2 days and I can’t find any problem...
    Any ideas???
  3. QUALITYTRUCK
    1,819
    1,783
    Jun 14, 2009
    romulus,mi
    Swapping LCM will not work. Each one programmed for each vehicle. "check LCM" is general term used by Volvo of that era to let you know you have a lighting problem. Very rare that LCM is bad.
    Goodysnap Thanks this.
  4. djtmy
    24
    Jan 28, 2015
    Dose anyone have wiring diagram? I don’t know where to start...
  5. djtmy
    24
    Jan 28, 2015
    Or maybe instruction how to check if LCM is good... voltage on pins etc... that will help a lot
  6. djtmy
    24
    Jan 28, 2015
    No one??? I’m still fighting with this problem.
  7. djtmy
    24
    Jan 28, 2015
    Additional problem is that I don’t have reverse light....
  8. jaylo
    jaylo Bobtail Member
    21
    18
    Jan 30, 2010
    wichita,ks
    LCM Manual
  9. Oliver Viote
    Oliver Viote Bobtail Member
    I have the same problem, did you fix it?
  10. mobilerepairboise
    mobilerepairboise Light Load Member
    61
    42
    Jul 10, 2018
    Boise Idaho
    Just find truck with good LCM and try it it will work
