06 volvo d12 fuel problem
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Danisuba19, Jan 3, 2014.
  1. smallbench
    smallbench Bobtail Member
    5
    Those problems starded when I've drained my tank really bad (1 and 2 filter replaced by the end of NOV) and last 3 situations happeneds last week when temp was below 0*F
    Any change that this problem will go away when temp is gonna get back to normal (20F of higher) ????
  3. HalpinUout
    HalpinUout Road Train Member
    7,074
    18,165
    Oct 2, 2011
    I drive a 05 670 and seems Im having the same issues... Last week from Chicago to New Mexico it was terrible like the truck barley wanted to accelerate then as soon as I got into Warmer weather around Albuquerque,NM and into Arizona it was back to normal... This week Chicago to Utah been doing the same stuff... It's the cold weather... As far as your "check engine ECU" any Volvo I've ever driven says the same thing including the one I'm in now and your Mechanic is right its nothing to worry about... This truck has 1.2 million on it...
  4. CondoCruiser
    CondoCruiser The Legend
    19,726
    18,734
    Apr 18, 2010
    Tennessee
    Anytime below freezing and especially below 20 make sure you treat your fuel with Power Service in the white jug or Howe's in the clear jug. Sure it costs but it's much cheaper than a breakdown.
    You north/south drivers especially. You buy your fuel down south you don't get the winter blend they sell up north. Up in the cold area's they'll mix like 10% #1 diesel with #2 which lowers it's gel point. But it only helps so much.
    If you plan on running in a cold area treat that fuel!! Any company will reimburse you. An OO it's tax deductible.
    My last job I run out of the midwest. Treating fuel goes with every fueling. If you notice up north the trash cans are full of fuel treatment jugs in the winter.
    The same goes with a reefer. Treat it's fuel.
    smallbench Thanks this.
  5. smallbench
    5
    So its only about the fuel and low temp?? Replacing the fuel pump or something its not gonna fix the problem?? What about that cooland getting to fuel injectors??
    I've changed 2filters since last fueling witch has a lot of threatments and yesterday my filters filled up once again after 40miles from changing (in -15F) and the engine turned off...
    Yesterday half of the trucks in my company coulnd't start but since they start the engine they were ok, but I cant trust my truck and hit the road even while was started...:/
  6. smallbench
    5
    Danisuba19 did you fixed that problem??????
  7. nikmirbre
    nikmirbre Road Train Member
    5,595
    10,382
    Jul 27, 2011
    High Point NC
    If your getting the same code as OP, then you should have your fuel pump checked....along with accessory drive....
  8. smallbench
    5
    If the fuel pump is bad would I have filters full of fuel??
  9. nikmirbre
    5,595
    10,382
    Jul 27, 2011
    High Point NC
    The same issues you two are having and same symptoms. Turned out to be my fuel pump...If anything go by a Volvo shop and have them pull that code....When my pump finally went out out on the side of the road, yes it was full of fuel.
  10. nikmirbre
    5,595
    10,382
    Jul 27, 2011
    High Point NC
    Also, I just thought of something. The code that you are getting is not the fuel filter code, the fuel filter code is the fuel pump with the rain drops next to it........the code with the fuel pump and lines under it indicates another issue....
  11. Danisuba19
    Danisuba19 Bobtail Member
    38
    4
    Jan 11, 2013
    Chicago il
    No i ihe been to the shop and everything lookss good they said. The temps went up and the problem went away. But i was told by another guy that o should look up a different filter that lets more fuel go through because of the cold and the bio in diesel it gets dense and its hard for it to go through. Basically what imma do now is im running clear diesel and i will see what happens now. Some stations have 20% bio oil some have 18, some 11, 5 but no more than 20 i wonder why? Couse it clugges up ur fuel system.
    1976bigred Thanks this.
