06 western star a/c help
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by dustinbrock, Jun 7, 2018.
  1. dustinbrock
    dustinbrock Road Train Member
    1,308
    901
    Apr 19, 2012
    North Battleford, SK
    Hey guys, I've got a 2006 western star 4900sa that I'm trying to get the air conditioning working on. I had Peterbilt replace the drier and compressor and a line or two then charge the system but it wouldn't work, they said they don't have the western star wiring diagrams so couldn't help any more.
    I'm now trying to get it going and first I thought to check the high and low pressure sensors but don't seem to have any......... All I find is a big 4 wire sensor plugged into the lines at the top of the AC drier (2 black 1 orange 1 yellow wire)
    No power to compressor.... Which of course is expected if there's a issue elsewhere. I'm not all too familiar with the AC on this unit so wondering if anyone can shed some light for where to start.
    I will double check but they said they filled the system as per the tag on firewall and a second shop filled it again when they took something apart and still nada
  3. swaan
    swaan Road Train Member
    2,942
    4,374
    Jul 12, 2009
    BC canada
    There is no separate high/ low pressure sensors.
    That big switch on top of dryer is the trinary switch. The power to the compressor runs through it. If refrigerant is to high or to low it cuts power to compressor. It's easy enough to replace. It's just a shrader valve.
    BoxCarKidd and dustinbrock Thank this.
  4. BoxCarKidd
    BoxCarKidd Road Train Member
    4,548
    6,641
    Aug 26, 2014
    It can get a little convaluted with different fan clutches. Most of them here have two hot wires on that plug. One of them is a low pressure switch and it goes to the wire next to it and powers the A/C clutch.
    The other one is for the fan ( engine ) and when the high side pressure gets up around 275-325 it connects and sends power to the fan solinoid. When the engine fan cuts in the head pressure comes down and the cycle continues. Some fan clutches are air engauged and there is a different trinary switch for them. I like manual fan switches as a adition.
    The wiring diagram is very complicated as the diagram is on the side of the new trinary switch. May be they installed the wrong one. There are not to many different ways to get that to operate the fan regardless of the engine or truck manufacture.
    This was one of the best working most simplistic systems ever made.
    Past that need to know some pressures.
    swaan and dustinbrock Thank this.
  5. DieselTech_Aus
    DieselTech_Aus Light Load Member
    274
    309
    Dec 20, 2017
    WA
    there will also be a thermal switch in the evaporator core. this cuts A/C compressor clutch power also when the core is too cold. this allows the core to warm back up and prevent the core freezing into one big ice block as would happen if the A/C compressor kept pumping gas.
    the low pressure liquid boils into a gas cooling the evaporator as it does. without regulation of this the core ices up and no air can flow over it.....
    provided the A/C clutch fuse isn't blown or power wires broken/shorted the only other signals that will cut A/C fan clutch power
    ECM overrides ie for over heats etc
    thermal switch in evaporator
    high pressure switch
    low pressure switch
  6. Mile high
    Mile high Bobtail Member
    I'm having problems with my air conditioning and I replaced everything and the fuse keeps blowing everything is new someone who can give me a hand????
  7. AModelCat
    164,645
    Probably got a wire rubbed through somewhere.
    JB7 Thanks this.
  8. ihc4b
    ihc4b Light Load Member
    52
    17
    Dec 29, 2021
    Having problems with my ac as well. Ac clutch stays engaged all the time. I believe this problem is also making my fan clutch stay on as well. I can disable the engine fan by jumping the power to the fan clutch selinoid and the selinoid will operate. New compressor , drier, trinary switch. Unplugging the trinary switch does nothing. Plugging the old trinary switch, but not screwed on the drier, does nothing.I have no positive power source at the dash switch or trinary switch. 2 wires at the dash switch show a ground with my test light probe, but the clip on a positive source. Trinary shows 2 strong ground terminals and on very weak ( dim light ) on my test light, 4th terminal does nothing. I don't see an ac fuse or relay in the fuse box. Beginning to think the ac might be controled by a pcm or something. Does anyone have a wiring diagram or expertise on this system?
  9. BoxCarKidd
    4,548
    6,641
    Aug 26, 2014
    Do you still have power to the clutch when the trinary is unpluged? If not is the clutch not locked engaged?
  10. ihc4b
    52
    17
    Dec 29, 2021
    Yes the clutch stays engaged all the time. Only thing that shuts it off is unplugging the compressor. Even with the trinary unplugged or the old trinary plugged in, buy not screwed onto the port. I have not had any positive source at the trinary or at the dash switch. With no ac fuse or relay in the fuse box, does the pcm or ecm control these functions
