07 International 9900i ign problem
Discussion in 'Trucks [ Eighteen Wheelers ]' started by AlekseyP, Jul 2, 2016.
  1. AlekseyP
    AlekseyP Bobtail Member
    Hi I went to start my truck today and after turning ignition to first position my F7-A fuse blow out I reset it and try ed again still same problem any idea what could be cousin the problem F7-A responsible for "key switch circuit & Related relays for ignition & ACC. Any help would be appreciated. Thx
  3. BoxCarKidd
    BoxCarKidd Road Train Member
    4,548
    6,641
    Aug 26, 2014
    I do not know but why is the one that is a problem the one you cannot read? Looks like it says ign switch some kind of relays and accessories. Use a process of elimination. Something like pull all the relays, F7-A related first. Turn the key on, did it blow? Continue on the best logical path you can. Fuses. breakers, chassis and engine harness type disconnect to narrow it down.
